+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 1
    Points: 1,446, Level: 8
    Join Date
    Jul 2005
    USA
    Posts
    19
    Points
    1,446
    Level
    8
    Help PLZ!! FPGA Clock
    Hi all
    I want to creat a clock from the input clock that has less frequency
    I tried this, however it is not working
    module(clk,...)
    input clk; // connected to C9 pin of Spartan3 XC3S200
    reg [0:25] count;
    reg clk2;
    allways @(posedge clk)
    begin
    count<=count + 1;
    clk2 <= count[25];
    end
    allways @(clk2)
    begin
    clk2<=0;
    end
    •   Alt4th March 2009, 18:45
      advertising
  2. #2
    Super Moderator
    Points: 239,566, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,505
    Points
    239,566
    Level
    100
    If you remove the second always block, the design should basically work as a 2**26 clock divider.
    •   Alt4th March 2009, 19:39
      advertising
  3. #3
    Join Date
    Jul 2005
    USA
    Posts
    19
    Points
    1,446
    Level
    8
    but I have to do s.th in my always block
    if I remove that I have to chek clk2 by if and I have an error with this syntax:
    begin
    count <= count + 1;
    clk2 <= count[25];
    end;
    if (clk2) //// ERROR:line 49 expecting 'endmodule', found 'if'
    begin
    clk2 <= 0;
    if (i<9)
    begin
    if (num[i]>num[i+1])
    begin
    temp<=num[i];
    •   Alt4th March 2009, 20:30
      advertising
  4. #4
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,505
    Points
    239,566
    Level
    100
    At least you have to remove clk2 <= 0, it's causing a multiple source error otherwise. The reg clk2 can be set in one always block only. Missing endmodule is another issue of course. You showed just some snippets, I didn't check the overall syntax, but it has to comply with Verilog rules as well.
    I you think, clk2 <= 0 is meaningful for your code, you have to redesign the first always respectively. You can use multiple concurrent assignment inside an always block (the last wins), so it would be possible within the first one.
  5. #5
    Member level 3
    Points: 1,232, Level: 7
    Join Date
    Feb 2009
    Posts
    65
    Points
    1,232
    Level
    7
    Re: Help PLZ!! FPGA Clock
    begin
    count <= count + 1;
    clk2 <= count[25];
    end;
    begin
    clk2 <= 0;
    if (i<9)
    begin
    begin
    temp<=num[i];
    if can only be used in "always" or "initial" block in RTL.
    if you want to do that ,you can use "assign";
    for example:
    wire a,b;
    assign a = (b) ? 1: 0;
    it equal to:
    if(b == 1)
    a = 1;
    else
    a = 0
