can +-12V be connected to provide supply voltage for LM741
videogudu
Newbie level 6
can +-12V be connected to provide supply to LM741 op-amp IC or +-15V should be given
Re: supply voltage for LM741
As I recall, the 741 will work down to about 4V. So +/-12V will be just fine.
The +/-15V is usuallyu given in the datasheet, but you do not need to work at those voltages.
