+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Points: 7,630, Level: 20
    Achievements:
    7 years registered
    AdvaRes's Avatar
    Join Date
    Feb 2008
    At home
    Posts
    1,166
    Points
    7,630
    Level
    20
    Crosstalks simulation tools ?
    Hi everybody ,
    Can somebody tell me which is the best tool to simulate crosstalks between on-chip interconnect's wires ?
    Thanks.
    •   Alt19th February 2009, 12:28
      advertising
  2. #2
    Points: 11,265, Level: 25
    Achievements:
    7 years registered
    kspalla's Avatar
    Join Date
    Aug 2008
    Hyderabad, Andhra Pradesh, India
    Posts
    1,256
    Points
    11,265
    Level
    25
    You can use CST or Ansoft SIwave, ADS EMDS
    •   Alt19th February 2009, 13:02
      advertising
  3. #3
    Achievements:
    7 years registered
    AdvaRes's Avatar
    Join Date
    Feb 2008
    At home
    Posts
    1,166
    Points
    7,630
    Level
    20
    Re: Crosstalks simulation tools ?
    Thanks kspalla,
    But aren't they for off chip interconnects (PCB) ?
    •   Alt19th February 2009, 14:18
      advertising
  4. #4
    Member level 1
    Points: 1,107, Level: 7
    Join Date
    Jan 2008
    Mexico
    Posts
    35
    Points
    1,107
    Level
    7
    in SIWave you can simulate the PKG of a chip, you can use also HFSS and Q3D from Ansoft. if you go for any of these directions, you should use the Ansoft Links tool to import your bondwires/solderballs/layout/etc. For higher freq you should use HFSS, if your structure is electrically short (lambda/10 rule) you can use Q3D, both tools are 3D Field Solvers. SIWave is a 2.5D solver, it aproximates the 3D sections, and but it solves very good the 2D parts. hope this helps :)
