+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Points: 710, Level: 5
    Join Date
    Feb 2009
    Posts
    Points
    710
    Level
    Help: Naming rules of passives and miscellaneous footprint
    We are using Altium to do EE design. But I meet some problem about footprint or schematic naming.
    For example, each resistor has several different footprints. Some refer to different wattages or different land pattern. But since the naming rules of footprint we are using are only based on geometric, like lead spacing and body size, I have no idea which resistor is which because the naming does not tell me.
    I am thinking about how to name the components more accurately.
    If anyone can give me some suggestions, I’ll greatly appreciate it.
    Thanks.
    •   Alt18th February 2009, 01:45
      advertising
  2. #2
    Full Member level 4
    Points: 3,626, Level: 14
    Achievements:
    7 years registered
    senilicus's Avatar
    Join Date
    Feb 2007
    Amsterdam / The Netherlands
    Posts
    226
    Points
    3,626
    Level
    14
    Re: Help: Naming rules of passives and miscellaneous footpri
    here at my compagnie we use the IPC land pattern naming conventions. Which is very usefull for almost all components. If we need to have more information we simply append this to the standard pattern name.
    You can find the document at http://landpatterns.ipc.org/files/IP...Convention.pdf
    a pattern name like CAPC1608X100N means a CAPacitor, Chip non polarized, bodylenght=1.6 body width=08mm, body height=1.0mm. If you want to add extra information the pattern name would be something like CAPC1608X100N_AVX-XR7 or wathever you want to add.
    And, you can use the land pattern wizzard from PCBmatrix to construct the patterns. This tool will save you a lot of time.
    •   Alt18th February 2009, 07:56
      advertising
  3. #3
    Newbie level 1
    Points: 664, Level: 5
    Join Date
    Mar 2009
    Posts
    Points
    664
    Level
    Hi everyone,
    I just started using Orcad PCB designer. In a design I would like to use a QFN component. In search for the footprint I found the Footprint Maker program.
    When I click to generate the footprint PCB designer opens but i get a error.
    E- Command not found: skill 'load "c:\\FPM\\fpm.il"'
    Please help me.
    Thank you in advance
