+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Points: 865, Level: 6
    Join Date
    Sep 2008
    Viet Nam
    Posts
    7
    Points
    865
    Level
    converting s11 to impedance
    Dear all.
    I'm a new comer, i wish to learn alot from you.
    I have designed a PA module using BLF278. but datasheet only give me S11,S12.S21.S22 and I need convert to Zin and Zout in complex impedance. (or how to use S-paramter)
    Please help me
    Thanks
    •   Alt16th February 2009, 15:55
      advertising
  2. #2
    Advanced Member level 5
    Points: 33,350, Level: 44
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,690
    Points
    33,350
    Level
    44
    s11 impedance
    Z = (1 + ρ)/(1-ρ)
    ρ = (Z-Z0)/(Z+Z0)
    Z0 is usually 50 ohms. These calculations are, of course, complex.
    •   Alt16th February 2009, 17:15
      advertising
  3. #3
    Points: 11,322, Level: 25
    Achievements:
    7 years registered
    kspalla's Avatar
    Join Date
    Aug 2008
    Hyderabad, Andhra Pradesh, India
    Posts
    1,256
    Points
    11,322
    Level
    25
    s11 to impedance
    You can use the calculations from the link
    http://www.rfcafe.com/references/electrical/s-h-y-z.htm
    1 members found this post helpful.
    •   Alt18th February 2009, 14:17
      advertising
  4. #4
    Join Date
    Sep 2008
    Viet Nam
    Posts
    7
    Points
    865
    Level
    convert s11 to impedance
    Thanks you very much for so many helps.
    But BLF278 only give me S11 and Φ; (see table). I must convert to Zs and Zl in complex impedance.
    Thanks.
  5. #5
    Join Date
    Dec 2004
    New England, USA
    Posts
    4,690
    Points
    33,350
    Level
    44
    s11 convert s22
    Maybe I wasn't clear enough.
    Zin = 50*(1 + S11)/(1 - S11)
    And
    Zout = 50*(1 + S22)/(1 - S22)
    where Zin and Zout are the impedances looking INTO the device. You have to mutiply by 50 to convert the normalized impedance into ohms (assuming your S parameters were measured on a 50 ohm network analyzer).
    The table you published has S11 as mag[s11] and ang[s11] for various frequencies. These are complex numbers. You do the complex division, one frequency at a time, and the answer is also a complex quantity, either in magnitude and angle, or Real and Imaginary parts, depending on how you choose to do the arithmetic.
    Rich
    www.MaguffinMicrowave.com
    •   Alt21st February 2009, 19:19
      advertising
  6. #6
    Advanced Member level 3
    Points: 13,776, Level: 28
    Join Date
    Feb 2002
    Posts
    749
    Points
    13,776
    Level
    28
    s11 conversion to impedance
    See below:
  7. #7
    Join Date
    Sep 2008
    Viet Nam
    Posts
    7
    Points
    865
    Level
    s11 to complex impedance
    thanks alot
