+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Junior Member level 1
    Points: 1,257, Level: 8
    Join Date
    May 2007
    Posts
    17
    Points
    1,257
    Level
    8
    DTMF decoder MT8870 for mobile phone
    Dear forum,
    Hope you are doing well.
    I have been working with the DTMF decoder MT8870 for few months but i could not get success. I have used few circuits mentioned in the datasheet. But i am facing problem *, 0, # , 7, 8 ,9 buttons are working but sometime works the 1, 2, 3, 4, 5, 6.
    Why is that???
    I have connected to MT8870 Pin 2, 3 ....> 100 Kohm
    But one thing i need to ask i have took dtmf toon from the mobile phone T68 speaker and connected to the MT8870 using a 5Kohm Variable resistance to control gain.
    What is the working cirucit for the mobile phone.
    Waiting for your supportive response.
    Regards
    Shan
    •   Alt15th February 2009, 13:56
      advertising
  2. #2
    Points: 1,432, Level: 8
    Achievements:
    7 years registered
    Join Date
    Oct 2010
    india
    Posts
    15
    Points
    1,432
    Level
    8
    Re: DTMF MT8870 Decoding
    try it.....
    To get good result use nokia 6600 with docomo/bsnl(in India)sim in decoder side.
    by Ur,
    sree
    ---------- Post added at 09:51 ---------- Previous post was at 09:46 ----------
    try another one
    ---------- Post added at 10:00 ---------- Previous post was at 09:51 ----------
    try it.......
    Circuit diagram shown in http://images.elektroda.net/55_1286856678.jpg
    please try 8.2k and 82k in the place of 8.2k resistor(marked in the image).To get good result use nokia 6600 with docomo/bsnl(in India)sim in decoder side. it worked with me
    by Ur,
    Sree
    •   Alt12th October 2010, 05:30
      advertising
  3. #3
    Newbie level 2
    Points: 398, Level: 4
    Join Date
    Oct 2010
    Posts
    Points
    398
    Level
    i made such a this circuit that you made. ihad some problems like you. And i took off the microphone of mobile phone. because the the signals that came from the microphone and keyboard of the mobile phone could mix. so it causes stability problems in your circuits. Try it and send me result. have a good works
    •   Alt12th October 2010, 07:29
      advertising
  4. #4
    Full Member level 6
    Points: 5,004, Level: 16
    Achievements:
    7 years registered
    welove8051's Avatar
    Join Date
    Jul 2009
    india
    Posts
    354
    Points
    5,004
    Level
    16
    Re: dtmf mt8870
    check this site a for a project called dtmf device control using micro controllerFREE PROJECTS ON HARDWARE(8051) AND SOFTWARE(VB, C,C++,JAVA...).
    make sure u using original dtmf decoder ic. cheap ic's doesnt respond well for some buttons. nokia phone works well. i didnt get satisfied results in samsung phones and one with usb connectors
  5. #5
    Newbie level 1
    Points: 107, Level: 1
    Join Date
    May 2012
    Posts
    Points
    107
    Level
    Re: DTMF decoder MT8870 for mobile phone
    Hi! I've built a poroject with the mt8870 and I've connected the Q1-Q4 outputs to LEDs so that I can see the codes, but when I call too the phone line by my Nokia 5800 and it would got busy, but the dtmf decoder doesn't seems to work :) any idea?:)
    •   Alt17th May 2012, 15:29
      advertising
  6. #6
    Advanced Member level 3
    Points: 4,828, Level: 16
    papunblg's Avatar
    Join Date
    Oct 2010
    Kolkata India
    Posts
    726
    Points
    4,828
    Level
    16
    Blog Entries
    9
    Rajsekhar Nag
    Knowledge Grows When Shared
