+ Post New Thread
Results 1 to 20 of 20
  1. #1
    Junior Member level 2
    Points: 1,390, Level: 8
    Join Date
    Aug 2006
    Posts
    22
    Points
    1,390
    Level
    8
    mosquito bat circuit
    Hi All,
    Does anyone know how to troubleshoot Electronic Mosquito Racket ?
    Because it can not generate the voltage to kill the mosquito anymore.
    So, how can it generate such a high voltage? And, the Electronic Mosquito Racket requires only 3 dc volts (2 batteries of 1.5 dcV) to work.
    On the other hand, I discovered one transformer which has six pin terminals. Is it a high frequency transformer or other component? I suspected it is spoiled but i dont know how to test it.
    Please help...
    •   Alt20th January 2009, 07:58
      advertising
  2. #2
    Member level 5
    Points: 2,019, Level: 10
    Achievements:
    7 years registered
    deepak007's Avatar
    Join Date
    Sep 2007
    Posts
    90
    Points
    2,019
    Level
    10
    mosquito racket circuit
    the bat contains two dc 1.5v cells. an oscillator circuit is also present.this changes the dc into ac.then,the ac is given to a miniature step up transformer.which gives 350v or more at the output with less current.when a mosquito falls across the two teminals,it gets shorted. the
    (just like an emergency light)
    tell me the make of the racket.is it a China one? then there will be a capacitor across the output terminal.it might be damaged.change it.
    if it is a tera power company make. the output section has many small capacitors.
    there is also a FET in the oscillator.when you press the switch on the bat,can you hear the oscillator sound?if so the FET is OK. if you cannot hear anything,then check the FET. if it is OK check the transformer.these transformers are available in india.where are you from?
    also check the batteries. the most overlooked part is the batteries.if the batteries are dead, purchase two AA rechargeable cells and solder them together in series and put them in the bat.
    follow the instructions above.if you cannot find the problem,can you post a picture of the bat?
  3. #3
    Newbie level 1
    Points: 673, Level: 5
    Join Date
    Mar 2009
    Posts
    Points
    673
    Level
    circuit for mosquito bat
    I purchased mosqutto racket (make of YPD brand,china one)for INR 125 & it worked well only for 3-4 days.
    Now it's generating very low voltage or current i.e. not able to kill any mosqutto.
    When I test it with tester like mosqutto, only small noise & spark is there,but not able to kill any mosqutto.
    I thought it's my bad luck & again purchased another one of same company. Within 3-4 days again same problem .
    When I press the button which is used to put current in racket,there is low contineous noise.
    I can post picture here too..
    It's very best soln for killing mosquttos & nice sleep,but company is bad.
    Plz tell me what can be the reason.
    Thanks in advance
    1 members found this post helpful.
  4. #4
    Newbie level 1
    Points: 508, Level: 4
    Join Date
    Feb 2010
    INDIA
    Posts
    Points
    508
    Level
    how to troubleshoot Electronic Mosquito Racket?
    Check output capacitor which on on seconadary side of transformer
  5. #5
    Member level 2
    Points: 745, Level: 5
    Join Date
    Jan 2010
    Posts
    43
    Points
    745
    Level
    Re: how to troubleshoot Electronic Mosquito Racket?
    have you traced the circuit?
    its similar to a SMPS circuit used in chargers for mobile phones
    here they are using a D965 transistor which is not a switching type transistor!!
    you should check if this transistor is OK. the pins are from left to right--- emitter, collector and base
    put in a MJE13001 switching transistor and see----however the pins are from left to right base , collector then emitter
    Edit: or the ferrite core transformer may have shorted turns
  6. #6
    Newbie level 1
    Points: 729, Level: 5
    Join Date
    Jul 2010
    kerala
    Posts
    Points
    729
    Level
    Hello friend,
    Check the push switch.Sometimes it gets rust inside and wont contact properly. The output voltage may not be sufficient to kill insects.Short the contacts of the switch with a screwdriver and watch the output. If u get full strength, clean or replace the switch.
    VU2PDA
  7. #7
    Member level 2
    Points: 1,070, Level: 7
    Join Date
    Sep 2008
    China
    Posts
    52
    Points
    1,070
    Level
    7
    I am learning
  8. #8
    Newbie level 1
    Points: 918, Level: 6
    Join Date
    Feb 2011
    Posts
    Points
    918
    Level
    Re: mosquito racket circuit
    Click image for larger version.
Name:	mosquito Killer bat 2.jpg
ID:	78130 so this the actual circuit of mosquito killer
    •   Alt4th August 2012, 15:53
      advertising
  9. #9
    Full Member level 3
    Points: 1,858, Level: 10
    Join Date
    Jun 2011
    Posts
    159
    Points
    1,858
    Level
    10
    @shekar
    yes it seems to be the circuit of the mosquito killer
    •   Alt4th August 2012, 17:08
      advertising
  10. #10
    Newbie level 1
    Points: 21, Level: 1
    Join Date
    Nov 2012
    Posts
    Points
    21
    Level
    This is the ckt dig of mosquito bat please look it now this is not work.Click image for larger version.
  11. #11
    Member level 1
    Points: 238, Level: 2
    Join Date
    Nov 2012
    Posts
    34
    Points
    238
    Level
    1, Measured across the battery with a multimeter DC voltage profile, normal should be about 3 volts to replace the battery lower than normal. Then check the battery clip is rusty, rust stains, use emery cloth to wipe clean.
    2, Check the micro switch is good contact or not, available multimeter to measure the resistance profile Continuity can judge whether good contact or not. If good contact, light-emitting diode will be lit. Otherwise, you want to check the light emitting diodes.
    3, The DC resistance of the check boosting transformer, the two groups is 0 ohm, one group is about 150 ohms, this group in the under power measurement, an AC voltage of about 350 volts.
  12. #12
    Points: 9,709, Level: 23
    ALERTLINKS's Avatar
    Join Date
    Dec 2003
    Pakistan
    Posts
    1,259
    Points
    9,709
    Level
    23
    I know. I know. And once more - I don't know.
    I am too old and would not have enough knowledge to judge, and only have made some remarks in order not to be called ignorant.
  13. #13
    Newbie level 1
    Points: 13, Level: 1
    Join Date
    May 2013
    Posts
    Points
    13
    Level
    I got a troubleshoot with my Mosquito bat .The charging light glows but it doesn't works .
  14. #14
    Newbie level 1
    Join Date
    May 2013
    Posts
    Points
    13
    Level
    Quote Originally Posted by shravan123 View Post
    mine too is charging but not making any sound can any body help me out/??
  15. #15
    Full Member level 2
    Points: 1,259, Level: 8
    burt007's Avatar
    Join Date
    Mar 2012
    Canada
    Posts
    144
    Points
    1,259
    Level
    8
    Re: mosquito bat circuit
    First of all a warning to Alexan,
    There are dangerously high voltage present, so unless you know electronics and familiar with the methods to test and troubleshoot, I suggest to stay away, this has usually the same circuit as the one found in gas lighter. I through away 3 of these rackets because of shorted nets and this is the most common fault. There are three of them the two outer-ones are ground and the inner one contains very high-voltages in the range of 3000 and up, look carefully and most likely you will find a dent in either outer or inner net of the racket, so it will be always shorted and no chance of generating high voltage and 90% of the time this is the problem, so straighten the net, remove short and try it, if this is not the case then post the result and we will look further.
    Quote Originally Posted by alexan_sim View Post
    Hi All,
    Please help...
  16. #16
    Newbie level 2
    Points: 17, Level: 1
    Join Date
    Dec 2013
    Posts
    Points
    17
    Level
    how can we test to know the transformer(6pin) is good or fault?
  17. #17
    Full Member level 6
    Points: 3,684, Level: 14
    Join Date
    Sep 2006
    MUMBAI INDIA
    Posts
    343
    Points
    3,684
    Level
    14
    check the continuity of transformer, primary side & secondary side.. if transformer is open , then their will be no continuity. if it is shorted then transistor on primary side becomes bad.
  18. #18
    Newbie level 2
    Join Date
    Dec 2013
    Posts
    Points
    17
    Level
    What is the name or model of transformer using in mosquito racket? it has primary, secondary & feeback winding.
  19. #19
    Full Member level 6
    Join Date
    Sep 2006
    MUMBAI INDIA
    Posts
    343
    Points
    3,684
    Level
    14
    its a sunca type emergency light transformer
    •   Alt18th December 2013, 10:44
      advertising
  20. #20
    Full Member level 2
    burt007's Avatar
    Join Date
    Mar 2012
    Canada
    Posts
    144
    Points
    1,259
    Level
    8
    These transformers are built for just these rackets, they are not any type or they are mosquitoes rackets type. When you are going to make millions of these products you don't choose off the markets type transformers. You simply calculate and make what you need. So the only thing left to do is find a bad or junk racket and use the parts from it, transistors and resistors and capacitors you can buy from anywhere but transformer NO.
    Quote Originally Posted by pradeep.g.belchada View Post
