+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Full Member level 5
    Points: 2,789, Level: 12
    Join Date
    Apr 2005
    Posts
    284
    Points
    2,789
    Level
    12
    clock ppm
    anyone tell me "clock frequency is 50MHz+/-50ppm?" what is really frequency?
    (50M+ 50/1,000,000)Hz? or (50M - 50/1,000,000)Hz?
    50/1,000,000 is very small ,almost can be ignored . I think.
  2. #2
    Points: 11,265, Level: 25
    Achievements:
    7 years registered
    kspalla's Avatar
    Join Date
    Aug 2008
    Hyderabad, Andhra Pradesh, India
    Posts
    1,256
    Points
    11,265
    Level
    25
    ppm clock
    You are right but this small time when accumulated over years then it creates an error of second per say.
    Some people may not interested in this error too.
    For the above calculation the frequency will lie between the two possible frequencies.
    •   Alt26th December 2008, 10:36
      advertising
  3. #3
    Super Moderator
    Points: 239,640, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    clock ppm calculation
    50 ppm at 50 MHz means a deviation of 2.5 kHz, an amount that isn't really small for a lot of applications.
    For a watch, 50 ppm implies an error of 26 minutes per year, for an UHF small band radio device, it would be considerably above tolerated error limits.
    •   Alt26th December 2008, 10:48
      advertising
  4. #4
    Full Member level 5
    Join Date
    Apr 2005
    Posts
    284
    Points
    2,789
    Level
    12
    clock ppm calculator
    if the samle frequency and different ppm in write clock and read clock ,Anyone can tell me how to calculate fifo depth ?
    •   Alt2nd January 2009, 04:21
      advertising
  5. #5
    Member level 1
    Points: 2,057, Level: 10
    Achievements:
    7 years registered
    Join Date
    May 2007
    Posts
    33
    Points
    2,057
    Level
    10
    clock frequency ppm
    hi feel_on_on
    i think if you meet case that different ppm in write clock and read clock, u have to consider worse case to calculate fifo depth.
    littlebu
  6. #6
    Full Member level 5
    Join Date
    Apr 2005
    Posts
    284
    Points
    2,789
    Level
    12
    how to compute ppm in clocks
    if read clock is 50Mhz+/-50ppm,write clock is 50Mhz+/-50ppm ,but they is the different clock . please tell me how to think about the fifo depth?
    Added after 1 hours 57 minutes:
    forget to speak ,the MAX transmit Unit is 1500 bytes
  7. #7
    Member level 4
    Points: 1,637, Level: 9
    Join Date
    Oct 2008
    Hyderabad
    Posts
    70
    Points
    1,637
    Level
    9
    what is clock ppm
    Quote Originally Posted by FvM
    Sir u have told deviation of 2.5 kHz, can i know with what formula u have calculated that......thanq u
  8. #8
    Super Moderator
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    50ppm
    50e-6*50e6=2500
  9. #9
    Newbie level 1
    Points: 332, Level: 3
    Join Date
    Feb 2011
    Posts
    Points
    332
    Level
    Re: clock frequency is 50MHz+/-50ppm?
    Here is how to calculate
    Convert ppm to Hz
    50 MHz nominal +/-50 ppm
    (50000000 / 1000000)*50 = +/- 2500 Hz which define the frequency bound of
    the oscillator to 49.9975 MHz <= f <= 50.0025 MHz
    Hope this will help
    •   Alt16th February 2011, 01:34
      advertising
  10. #10
    Newbie level 3
    Points: 933, Level: 6
    Join Date
    Nov 2008
    Posts
    Points
    933
    Level
    Friends check this link for PPM to Hz and vice - versa conversion:
    http://www.jittertime.com/resources/ppmcalc.shtml
