Allen Bradley RSLOGIX-what programming software to purchse?
CrabMan
Member level 1
Pakistan
n71 allen bradley starter troubleshooting
We have a AB SLC5/05 PLC, my query is what programming software package should we purchase? THere are 2 options the Starter and the Standard. The main difference between the starter and Standard is that Starter is for offline programming and online monitoring only whereas standard supports online programming and monitoring too. What is the difference between offline programming and online programming?
Thanks in advance....
allen bradley rslogix
Hello CrabMan,
OnLine programming means that you are able to modify the PLC program with the PLC running the application.
Bottom line of Allen Bradley PLCs (MicroLogix) can only be programmed Off Line, however, from the SLC500 and up you don't need to stop the PLC to do manteniance or modification of the program.
That capabilty is important if you cuold not afford to stop all the controlled process to do minimal modifications. (think in a chemical process plant, by example).
Obviously, you must be carefull with your modifications, as you can blow anything in case of programming mistake.
Hope this helps you to select your package.
Regards
    CrabMan
rslogix
Online monitoring is important for troubleshooting purposes. It makes it much quicker and easier to troubleshoot PLC controlled machine with online monitoring.
    CrabMan
troubleshooting rslogix
thanks guys for helping me make the decision and we are now goin for a standard package as the PLC is installed in a Ball mill controlling a burner and all other processes......
thanks for your input
