include 16f84_4
include jlib
port_b_direction = all_output
port_a_direction = all_output
var byte d1 = 0,d2 = 0,d3 = 0,d4 = 0
procedure arttir is
d1 = d1 + 1
if d1 == 10 then
d1 = 0
d2 = d2 + 1
if d2 == 6 then
d2 = 0
d3 = d3 + 1
if d3 == 10 then
d3 = 0
d4 = d4 + 1
end if
end if
end if
if d4 == 2 & d3 == 4 then d3 = 0 d4 = 0 end if
end procedure
procedure tara is
port_a = 0
for 10 loop
port_b = seven_from_digit ( d1 )
pin_a0 = high
delay_5ms
pin_a0 = low
port_b = seven_from_digit ( d2 )
pin_a1 = high
delay_5ms
pin_a1 = low
port_b = seven_from_digit ( d3 )
pin_a2 = high
delay_5ms
pin_a2 = low
port_b = seven_from_digit ( d4 )
pin_a3 = high
delay_5ms
pin_a3 = low
end loop
end procedure
forever loop
arttir
tara
end loop
