+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Member level 3
    Points: 1,142, Level: 7
    Join Date
    Nov 2008
    Posts
    57
    Points
    1,142
    Level
    7
    dbi to dbm
    Hi ,
    I have a doubt. Please help me.
    Actually, I am testing an patch antenna using sweep oscillator as transmitter and signal generator as receiver.
    In the sweep oscillator, I key-in -10dBm in the power level "display" and also key-in -10dBm of "reference level" in the signal generator. In both equipments, I have key-in the frequency range from 1.4GHz to 1.5GHz.
    I'm getting a waveform. I too getting value in dBm in the signal generator when transmitting from sweep oscillator but don't know how to calculate the gain......
    Could anybody guide me how to calculate......
    I need the answer in dBi.
    Urgent!Urgent!Urgent!
    Please help me.
    Waiting for your reply.
    Thank you.
  2. #2
    Full Member level 1
    Points: 3,035, Level: 12
    Join Date
    Mar 2002
    Posts
    108
    Points
    3,035
    Level
    12
    dbi to dbm conversion
    dBi or dB(isotropic) is the forward gain of an antenna compared to the hypothetical isotropic antenna, which uniformly distributes energy in all directions.
    dBm or dB(mW) is the power relative to 1 milliwatt.
    Therefore, are two different quantities. You have to calculate the hypothetical power trasmitted from an isotropic antenna in your situation and then you have to compare to the power trasmitted, in the same situation, from your real antenna. This ratio (in dB), power trasmitted (real antenna)/power trasmitted (isotropic antenna), is dBi of your antenna.
    Regards
    1 members found this post helpful.
    •   Alt24th November 2008, 13:30
      advertising
  3. #3
    Member level 3
    Join Date
    Nov 2008
    Posts
    57
    Points
    1,142
    Level
    7
    convert dbi to dbm
    Hi yuyu,
    I need your guidance again.
    According to my situation which I explained to you earlier, when I transmit at -10dBm in sweep oscillator , I'm getting around -60dBm in signal generator. In signal generator, to see the dBm value, I press Channel Power icon to see the dBm value and it shows -60dBm when transmits.
    So to find the gain, do I need to calculate as below:
    10 log Pout( in dBm) / Pin(in dBm) = ? dBi
    Pout = -60dBm (at signal generator)
    Pin= -10dBm ( at sweep oscillator)
    So , if I follow the formulae above, I'm getting about 7.7 .
    Should I assume 7.7dBi?
    Please guide me .
    I'm really need your help.
    Thank you.
    regards,
    saran
    •   Alt25th November 2008, 03:20
      advertising
  4. #4
    Full Member level 1
    Join Date
    Mar 2002
    Posts
    108
    Points
    3,035
    Level
    12
    dbi dbm
    Dear saran7507,
    you have to consider the Friis transmission equation: Pr/Pt=(lambda/4PgrR)2GtGr
    Pr=power received from the patch antenna
    Pt=power transmitted from the patch antenna
    R=distance
    lambda=wave length
    Gt=gain of transmitting antenna (the patch antenna)
    Gr=gain of receiving antenna (the term include the losses of the receiving system)
    Pgr=3.14
    You already know the first 4 terms. You have to know the Gr term. Then is it possible to calculate Gt:
    Gt= (4PgrR/lambda)2 Pr/(Pt*Gr)
    Gt (dBi)= 10 log Gt
    Alternatively, if you consider an hypothetical isotropic antenna then:
    Priso=power received from an hypothetical isotropic antenna (you have to calculate)
    Priso=Pt Gr (lambda/4PgrR)2 Gtiso = Pt Gr (lambda/4PgrR)2
    Gtiso=gain of hypothetical isotropic antenna=1 (0 dBi)
    since
    Pr=Pt Gr (lamda/4PgrR)2 Gt
    the ratio between Pr and Priso is the gain of transmitting antenna
    Pr/Priso= Gt
    Regards
    •   Alt25th November 2008, 14:32
      advertising
  5. #5
    Member level 3
    Join Date
    Nov 2008
    Posts
    57
    Points
    1,142
    Level
    7
    convert dbi to db
    Hi yuyu,
    Thanks for giving me the solution.
    Again, I have some doubt.
    As you told me about the friis transmission equation, I don't understand the difference between Pr,Pt and Gr,Gt.
    According to my situation in testing the 1.45GHz(centre frequency) patch antenna, I am using the sweep oscillator as transmitter by keying -10dBm at power level icon and using signal generator as receiver and I'm getting about -60dBm.
    Question 1:
    Normally to find the gain, do we use the formulae below:
    Gain=10 log (Pout/Pin)
    Since I'm looking for dBi in the gain, which gain equation should use? The formulae that u gave me or use the formulae above.
    According to practical value above which are -10dBm and -60dBm, how should I find the gain in dBi?
    Question 2:
    Using the friis equation, where do I need to apply -10dBm and -60dBm. Is that Gr, Pr, Pt or ...? I'm confused.
    Please reply me. I really need your help. Urgent!Urgent!Urgent!
    Thank you.
    Regards,
    Saran.
    [/u]
  6. #6
    Full Member level 2
    Points: 2,787, Level: 12
    Join Date
    Oct 2004
    Posts
    127
    Points
    2,787
    Level
    12
    dbm to dbi
    antenna is one port device, it is different from two ports device which gain is defined as your description, gain=10db(pout/pin).
  7. #7
    Advanced Member level 1
    Points: 4,907, Level: 16
    Join Date
    Jul 2005
    Posts
    452
    Points
    4,907
    Level
    16
    dbm dbi
    Quote Originally Posted by saran7507
    Hi yuyu,
    So 10log(60)=17.7
    and then you substract
    17.7- 10 = 7.7 dB?
    I think you have a long road ahead of you....
    That is the reason some people are recommending you
    to read Balanis....it is a long explanation...too long for
    a forum....
    You need to read a lot, and take some courses in Antennas.
    •   Alt26th November 2008, 15:18
      advertising
  8. #8
    Member level 3
    Join Date
    Nov 2008
    Posts
    57
    Points
    1,142
    Level
    7
    convert dbm to dbi
    Hi yuyu,
    Thanks for your answer.
    Based on the data's that I gave you, from your point of view, how would you calculate to find the gain in dBi. Explain me in your way, please.
    Sorry to trouble you.
    Lastly, How would you recommend me to find the gain?
    Please list down to me.
    I would be very grateful to you if you help me.
    Thank you.
    Regards,
    Saran
  9. #9
    Full Member level 1
    Join Date
    Mar 2002
    Posts
    108
    Points
    3,035
    Level
    12
    db to dbi conversion
    Dear Saran,
    I attached a file regarding your problem.
    Regards
