Interface to 4x4 Keypad - how to scan the keypad correctly?
Maverickmax
Advanced Member level 1
Hi
I am struggling to interface my 4x4 Keypad as I connected 4 rows and columns to P0H to P0H7 respectively. I tried to scan it but I kept getting incorrect data. How can I scan the keypad correctly?
I use column as output and row as input.
Please advise me asap
MM
Re: Interface to 4x4 Keypad
What is your reading sequence ?
Added after 54 seconds:
And the schematic
Added after 2 hours 22 minutes:
I imagine you are already doing the next:
Initial column value = 0
Set 1 to Column # 1
Read the input - If data != 0 then you have key(s) pressed
Set 0 to Column # 1
Set 1 to Column # 2
Set 0 to Column # 2
Set 1 to Column # 3
Set 0 to Column # 3
Set 1 to Column # 4
Set 0 to Column # 4
Delay to avoid bouncing
Since I set the columns high and rows as input but each row has a pull-up resistor. So the inputs of row would be high. When key is depressed, say 1. The software will carry algorithm such as setting column to zero one by one. For example:
0111
1011
1101
1110
While key "1" is depressed and column number 1 set to zero which will override row 1 to zero. As button 1 releases, the 1st row will go back to one due to a pull-up resistor. Is that correct?
MM
If you have pull-up resistors you cannot set the column to 1 to read each row.
But, to help you better, please send the schematics.
