+ Post New Thread
Results 1 to 9 of 9
  1. #1
    Junior Member level 2
    Points: 1,371, Level: 8
    Join Date
    Nov 2008
    India
    Posts
    21
    Points
    1,371
    Level
    8
    Current Transformer
    Hi
    How to calculate burden resistance required for CT of ratio 50:5, is thr any formula for it??
    Thanks
    •   Alt19th November 2008, 18:01
      advertising
  2. #2
    Advanced Member level 5
    Points: 20,960, Level: 35
    VVV's Avatar
    Join Date
    Nov 2004
    Posts
    1,582
    Points
    20,960
    Level
    35
    Re: Current Transformer
    Usually this is simply chosen so that for the given primary current you get the required voltage.
    Say you need 1V at 1A with your transformer. The secondary current is going to be 0.1A when the primary current is 1A. So R=1V/0.1A=10 ohm.
    There are other things to consider, but you are not designing the current transformer, you are just using it. So that's pretty much it.
  3. #3
    Join Date
    Nov 2008
    India
    Posts
    21
    Points
    1,371
    Level
    8
    Current Transformer
    Thanks VVV
    Can help u tell me Which rectifier will be better to convert o/p of this CT to DC vtg. normal bridge rectifier or any special one.
    •   Alt19th November 2008, 18:27
      advertising
  4. #4
    Advanced Member level 1
    Points: 7,503, Level: 20
    Awarapunshee's Avatar
    Join Date
    Jul 2007
    Some Where In Heaven
    Posts
    413
    Points
    7,503
    Level
    20
    Yes a normal rectifier can do the job, even 1N4148 can do it.
    •   Alt20th November 2008, 08:59
      advertising
  5. #5
    VVV's Avatar
    Join Date
    Nov 2004
    Posts
    1,582
    Points
    20,960
    Level
    35
    A single rectifier will do. Generally, the 1N4148 is a good choice. Just make sure you do not exceed the peak current, or choose a different diode. A fast diode is always a better choice.
  6. #6
    Member level 4
    Points: 2,468, Level: 11
    Achievements:
    7 years registered
    Join Date
    Feb 2007
    Posts
    78
    Points
    2,468
    Level
    11
    I hope that you know that you may have to factor in the diode drop to get required accuracy.
    1N4148 has upto max of 1V.
    Maybe some further reading on precision rectifiers,could be useful.
  7. #7
    Join Date
    Nov 2008
    India
    Posts
    21
    Points
    1,371
    Level
    8
    Current Transformer
    can you suggest me any precision amplifier for this application???
  8. #8
    Points: 3,085, Level: 13
    Join Date
    Sep 2006
    Posts
    440
    Points
    3,085
    Level
    13
    Op amp is often used to make a precision rectifier, you can refer to any book/datasheet/application notes of op-amp.
    •   Alt26th November 2008, 05:20
      advertising
  9. #9
    Newbie level 6
    Points: 1,033, Level: 7
    Join Date
    Feb 2008
    Posts
    12
    Points
    1,033
    Level
    7
    Re: Current Transformer - how to calculate burden resistance
    hi
    formula
    ADC maximum input voltage = (IMAX/ct ratio)*burden resistor
