How to Control multiple Servo Motors using 89 series
divit
Newbie level 6
multiple servo diagram
I need to generate pwn signals at port 0.0-0.7 and port 2.0-2.7.The pwm signals should change their Ton period according to digital value received from the adc by each sensor.every pin will hav a different pwn signal according to correspoding value of the sensor.the sensor will basically be a 5k ohm pot .the pwm signals will run a servo motor.the servo motor should move between 0 to 90 degrees.I am also posting the schematic please help me out i need to do this for my final year project
I am making a dex hand which works on an adc and AT98S52.
I dont knw how to program a ic i have the circuit diagram i just need help if some 1 could giv me the coding for it. There are 16 sensors (i am using 5k ohm pots as sensors) .The sensors are given to the adc the adc will generate a digital value and give it to micro controller.The micro controller will then generate a pwm signal .The pwm signal is then given to the servo motors. I basically need a program which will enable each servo motor to move according to the adc value received.Therefore each each pot will drive a single servo motor.
pic multiple pwm servo motor
I have not designed on atmel before, only on PIC series.
How much code have you designed yet, have you developed the hardware.
I am sure you would have worked out the ADC control modules (to receive analogue data).
Is there any feedback generated by the servo??
thanks
aa
multiple servo motor
the thing is i havent started with the project yet i have the blueprints and ciruit diagram this is my 1st time using micro controllers in a prject and i dont knw how to program in C and i hav basic knowledge of assembly language or hex coding u can.I am trying to learn but will take me alot of time so i decided tht if i could get the programs in parts i could just put it together and burn it .But unfortunaelty i havent got anything of the program yet
I doubt tht it has a feedback cause i need it to displace from 0 to 90 degrees ill also post u how the actual hand looks like plz note tht this project is not designed by me
Added after 3 minutes:
I found out a coding in .asm format but its used for PIC and only for single pwm heres the link to the site and also posting the .asm file
https://www.rc-cam.com/servotst.htm
