+ Post New Thread
Results 1 to 11 of 11
  1. #1
    Full Member level 1
    Points: 2,039, Level: 10
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    Posts
    101
    Points
    2,039
    Level
    10
    Replacement for a SK 100 transistor
    Hello i am implementing switching ckt bt i am no able to find SK100 transistor. plz tell me the replacement of tis transistor with any other of same specifications.
  2. #2
    Advanced Member level 3
    Points: 6,212, Level: 18
    Join Date
    Apr 2006
    Hyderabad, India.
    Posts
    789
    Points
    6,212
    Level
    18
    transistor sk100
    Quote Originally Posted by Adil Israr
    It is a pnp transistor i believe
    you can use BD138
    though darlington, it would work. lesser bias current is needed as the gain is high gain device
    if the current demand is less like 250mA. Perhaps 2n5401 /2n5551 depending on the polarity would also be useful
    In case you are from India, the same device is available f as CK100, BEL100P, etc
    •   Alt9th November 2008, 14:40
      advertising
  3. #3
    Full Member level 1
    Achievements:
    7 years registered
    Join Date
    Sep 2008
    Posts
    101
    Points
    2,039
    Level
    10
    sk100 pnp transistor
    Ya it is pnp,bt im nt 4rm india, im frm pak.will the above one helpful,,i want to use it in mute switch with relay.
    •   Alt12th November 2008, 18:58
      advertising
  4. #4
    Member level 3
    Points: 1,422, Level: 8
    Join Date
    Dec 2009
    Hyderabad
    Posts
    64
    Points
    1,422
    Level
    8
    Re: Replacement for a SK 100 transistor
    hi 2 all
    i am krishnamraju i just need a help from u i was using sk100 in place of sk100 what can i use but the package which i was going to use should be in smd pls help me i was in urgent :at the i was using bc177 in case of using bc177 iwas using rn2045 can i use rn2405 sad:
    •   Alt22nd June 2011, 12:13
      advertising
  5. #5
    Points: 17,009, Level: 31
    kak111's Avatar
    Join Date
    Mar 2011
    Finland
    Posts
    1,366
    Points
    17,009
    Level
    31
    Blog Entries
    8
    Look this thread , you find dataheet SL100 and SK100
    http://www.edaboard.com/thread214367.html
    KAK
    ---> Hike with wise men , then you will be wise <---
  6. #6
    Member level 3
    Join Date
    Dec 2009
    Hyderabad
    Posts
    64
    Points
    1,422
    Level
    8
    hi
    thanku for replay but i want to use smd transistor
  7. #7
    Newbie level 1
    Points: 1,829, Level: 9
    Join Date
    Nov 2005
    Posts
    Points
    1,829
    Level
    9
    Re: Replacement for a SK 100 transistor and SL100
    plz tell me replacement for SK100 transistor and SL100 for moscet repeller circuit
  8. #8
    Advanced Member level 2
    Points: 4,314, Level: 15
    Achievements:
    7 years registered
    Pjdd's Avatar
    Join Date
    Jan 2011
    Posts
    505
    Points
    4,314
    Level
    15
    Sk100 - 2n3019, 2sa684, bc327
    sl100 - 2n4033, 2sc1384, bc337
    1 members found this post helpful.
    •   Alt15th December 2011, 08:10
      advertising
  9. #9
    Junior Member level 3
    Points: 555, Level: 5
    swami.gangatharan's Avatar
    Join Date
    Feb 2012
    CHENNAI, INDIA
    Posts
    29
    Points
    555
    Level
    thank you for your information..
    ---------- Post added at 15:56 ---------- Previous post was at 15:46 ----------
    SK100 is a PNP and 2n3019 is a NPN . then how it will be a correct replacement?????
  10. #10
    Points: 7,708, Level: 20
    Raza's Avatar
    Join Date
    Feb 2002
    PAK
    Posts
    829
    Points
    7,708
    Level
    20
    SK100.......... TO39
    Ic=500 mA
    Vce=50V
    Vcb=60V
    Veb=5V
    Pd=800 mW
    A general purpose PNP
    BC640........... TO92 case
    Ic=-1000 mA
    Vce=-80V
    Veb=-5V
    Pd=1W
    A general purpose High collector current PNP.
    Works very nice in switching applications.
  11. #11
    Achievements:
    7 years registered
    Pjdd's Avatar
    Join Date
    Jan 2011
    Posts
    505
    Points
    4,314
    Level
    15
    Quote Originally Posted by swami.gangatharan View Post
    Oops!! Sorry, that was a typo. Just interchange 2N3019 and 2N4033 above.
