how to implement rtos in microblaz
senthilkumar
Advanced Member level 1
india
hai,
anyone to implement the rtos in microblaz.
if yes what rtos to easy one for gui application.
thanks
Have a look at microC-OS (uC-OS) at http://www.ucos-ii.com/ . You can download a Microblaze port from there for free. You should buy the book to get the full OS. There is a GUI addon which you can buy, also a Filesystem addon.
Git
if i download the porting code and ex1 and load to edk3.2
after compile they give error like this
Command bash -c "cd /xygdrive/d/work/multimedia_board/Ex1/; make -f system.make program; exit;" Started...
mb-gcc -O2 code/test.c code/bsp.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_core.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_flag.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_mbox.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_mem.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_mutex.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_q.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_sem.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_task.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_time.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_dbg.c D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_cpu_a.s D:\\work\\multimedia_board\\Hello_World\\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\\uCOS-II-MicroBlaze\\os_cpu_c.c -o mblaze/code/executable.elf \
-g -I./mblaze/include/ -Icode -IuCOS-II -IuCOS-II-MicroBlaze -L./mblaze/lib/ \
-xl-mode-executable \
In file included from code/test.c:25:
code/includes.h:23: ucos_ii.h: No such file or directory
In file included from code/bsp.c:13:
In file included from C:/EDK/sw/iplib/drivers/intc_v1_00_b/src/xintc_l.h:48,
from D:/work/multimedia_board/Hello_World/MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1/code/includes.h:21,
from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_core.c:17:
mblaze/include/xparameters.h:19: warning: `XPAR_XUARTLITE_NUM_INSTANCES' redefined
C:/EDK/sw/iplib/drivers/common_v1_00_a/src/xparameters.h:147: warning: this is the location of the previous definition
mblaze/include/xparameters.h:27: warning: `XPAR_XGPIO_NUM_INSTANCES' redefined
C:/EDK/sw/iplib/drivers/common_v1_00_a/src/xparameters.h:251: warning: this is the location of the previous definition
mblaze/include/xparameters.h:48: warning: `XPAR_INTC_MAX_NUM_INTR_INPUTS' redefined
C:/EDK/sw/iplib/drivers/common_v1_00_a/src/xparameters.h:89: warning: this is the location of the previous definition
mblaze/include/xparameters.h:49: warning: `XPAR_INTC_SINGLE_BASEADDR' redefined
C:/EDK/sw/iplib/drivers/common_v1_00_a/src/xparameters.h:90: warning: this is the location of the previous definition
mblaze/include/xparameters.h:51: warning: `XPAR_XINTC_NUM_INSTANCES' redefined
C:/EDK/sw/iplib/drivers/common_v1_00_a/src/xparameters.h:88: warning: this is the location of the previous definition
In file included from D:/work/multimedia_board/Hello_World/MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1/code/includes.h:23,
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:953: #error "OS_CFG.H, Missing OS_FLAG_EN: Enable (1) or Disable (0) code generation for Event Flags"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:991: #error "OS_CFG.H, Missing OS_MBOX_EN: Enable (1) or Disable (0) code generation for MAILBOXES"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1021: #error "OS_CFG.H, Missing OS_MEM_EN: Enable (1) or Disable (0) code generation for MEMORY MANAGER"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1047: #error "OS_CFG.H, Missing OS_MUTEX_EN: Enable (1) or Disable (0) code generation for MUTEX"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1069: #error "OS_CFG.H, Missing OS_Q_EN: Enable (1) or Disable (0) code generation for QUEUES"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1115: #error "OS_CFG.H, Missing OS_SEM_EN: Enable (1) or Disable (0) code generation for SEMAPHORES"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1137: #error "OS_CFG.H, Missing OS_MAX_TASKS: Max. number of tasks in your application"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1148: #error "OS_CFG.H, Missing OS_TASK_IDLE_STK_SIZE: Idle task stack size"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1152: #error "OS_CFG.H, Missing OS_TASK_STAT_EN: Enable (1) or Disable(0) the statistics task"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1156: #error "OS_CFG.H, Missing OS_TASK_STAT_STK_SIZE: Statistics task stack size"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1160: #error "OS_CFG.H, Missing OS_TASK_STAT_STK_CHK_EN: Check task stacks from statistics task"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1164: #error "OS_CFG.H, Missing OS_TASK_CHANGE_PRIO_EN: Include code for OSTaskChangePrio()"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1168: #error "OS_CFG.H, Missing OS_TASK_CREATE_EN: Include code for OSTaskCreate()"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1172: #error "OS_CFG.H, Missing OS_TASK_CREATE_EXT_EN: Include code for OSTaskCreateExt()"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1176: #error "OS_CFG.H, Missing OS_TASK_DEL_EN: Include code for OSTaskDel()"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1180: #error "OS_CFG.H, Missing OS_TASK_NAME_SIZE: Determine the size of task names"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1184: #error "OS_CFG.H, Missing OS_TASK_SUSPEND_EN: Include code for OSTaskSuspend() and OSTaskResume()"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1188: #error "OS_CFG.H, Missing OS_TASK_QUERY_EN: Include code for OSTaskQuery()"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1198: #error "OS_CFG.H, Missing OS_TICKS_PER_SEC: Sets the number of ticks in one second"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1202: #error "OS_CFG.H, Missing OS_TIME_DLY_HMSM_EN: Include code for OSTimeDlyHMSM()"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1206: #error "OS_CFG.H, Missing OS_TIME_DLY_RESUME_EN: Include code for OSTimeDlyResume()"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1210: #error "OS_CFG.H, Missing OS_TIME_GET_SET_EN: Include code for OSTimeGet() and OSTimeSet()"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1220: #error "OS_CFG.H, Missing OS_ARG_CHK_EN: Enable (1) or Disable (0) argument checking"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1224: #error "OS_CFG.H, Missing OS_CPU_HOOKS_EN: uC/OS-II hooks are found in the processor port files when 1"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1228: #error "OS_CFG.H, Missing OS_LOWEST_PRIO: Defines the lowest priority that can be assigned"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1232: #error "OS_CFG.H, Missing OS_MAX_EVENTS: Max. number of event control blocks in your application"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1240: #error "OS_CFG.H, Missing OS_SCHED_LOCK_EN: Include code for OSSchedLock() and OSSchedUnlock()"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1244: #error "OS_CFG.H, Missing OS_TASK_PROFILE_EN: Include data structure for run-time task profiling"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1248: #error "OS_CFG.H, Missing OS_TASK_SW_HOOK_EN: Allows you to include the code for OSTaskSwHook() or not"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1252: #error "OS_CFG.H, Missing OS_TICK_STEP_EN: Allows to 'step' one tick at a time with uC/OS-View"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1256: #error "OS_CFG.H, Missing OS_TIME_TICK_HOOK_EN: Allows you to include the code for OSTimeTickHook() or not"
C:/SOFTWARE/uCOS-II/SOURCE/ucos_ii.h:1260: #error "OS_CFG.H, Missing OS_DEBUG_EN: Allows you to include variables for debugging or not"
from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_flag.c:16:
from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_mbox.c:16:
from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_mem.c:16:
from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_mutex.c:16:
from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_q.c:16:
from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_sem.c:16:
from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_task.c:16:
from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_time.c:16:
from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_dbg.c:15:
In file included from D:\work\multimedia_board\Hello_World\MicroBlaze_Media_Brd_Demo_jtag_edk3_2_sp1\uCOS-II-MicroBlaze\os_cpu_c.c:19:
make: *** [mblaze/code/executable.elf] Error 1
Done.
I decided not to "quote" that message :)
I would think there are at least two prblems there. The main one is that the compiler cannot find the path for the rtos Includes - you need to tell the compiler where they are. Double click the CPU entry in the System tree and look at the Directories tab of S/W Settings. You need to put the paths to the rtos includes in the Includes section.
You also need to look at OS_CFG.H and configure it how you need it. I think you need to buy the book...
Git
