tyassin
Advanced Member level 1
Hi
If you have a patch antenna with finite ground plane. How to setup the airbox correct?
I have used minimum \[\lambda\]/4 as a distance to my antenna structure.
But lets say you have an antenna with a very small ground-plane and you still need the \[\lambda\]/4 as minimum distance. Then there is a gap between the antenna and radiation box.
Should this be filled with a radiation plane?
Hope this make sense
Thank you
Thank you
