+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 2
    Points: 1,901, Level: 10
    Join Date
    Aug 2006
    Posts
    42
    Points
    1,901
    Level
    10
    r2r calculate
    Is the equation below all right or are there any some mistakes?
    From the pic, current flowing the feedback res is If
    And the vout=vcm+If*R can we get: vout in the pic
    and the digital input code is sequenced from 0000 0000 to 1111 1111,and what’s the output of the dac ?
    pic is attached here:
    •   Alt28th August 2008, 14:35
      advertising
  2. #2
    Full Member level 1
    Points: 2,082, Level: 10
    Join Date
    Jan 2005
    Posts
    100
    Points
    2,082
    Level
    10
    r/2r dac equation
    could you re-upload a more clear pic?
    in generally, the r2r calculate is easy, please from the terminal close the vref,then one by one to the termal close the opamp.
    •   Alt3rd September 2008, 16:03
      advertising
  3. #3
    Member level 4
    Points: 1,724, Level: 9
    jwfan's Avatar
    Join Date
    Nov 2005
    Earth
    Posts
    70
    Points
    1,724
    Level
    9
    caclulation of a R2R dac ladder
    Google it. :)
    •   Alt3rd September 2008, 18:05
      advertising
  4. #4
    Member level 2
    Points: 2,018, Level: 10
    Achievements:
    7 years registered
    Join Date
    Jun 2008
    Hungary
    Posts
    42
    Points
    2,018
    Level
    10
    Re: caclulation of a R2R dac ladder
    I do not understand the analysis of the R2R ladders. My main concern is that the different bits are seeing different resistances. If we look downwards all the resistances are 2R, but not upwards! For example the weight of b(n-2) should be (R+2R)||2R/((R+2R)||2R+2R)=3/8
    For a 2 bit DAC the outputs would be:
    0, 3/8, 4/8, 7/8
    So looking upwards from the right end of a 2R resistor we see a resistance which depends on the distance of the output node. Thus the bits are not binary weighted.
    Could somebody resolve this?
    Added after 2 hours 20 minutes:
    Quote Originally Posted by tzg6sa
    0, 3/8, 4/8, 7/8
    I see now. I did not finished the calculation. There is a voltage divider to the output. Taken into account the dividing ratio I get the correct binary weight.
