How to calculate BJT NPN transistor using beta?
Rumieus
Junior Member level 2
Ib=V1/R1 = 0.1mA
Ic=V1/R2 = 10mA
β=100
Am i right?
In designing circuit, do we calculate Ic using β or using the V=IR because in book which im currently studying, all the calculation are using β to calculate Ic but if β is 50 and then the Ic is different right?
Im just so confuse with electronic..
What are the different between dis 2 circuit?
bjt npn transistors
Well
Ib=(V1-Vbe)/R1=(10V-0.65V)/100KΩ≈93.5uA
If BJT work in active region Ic is equal
Ic=Ib*β=93.5uA*β
So if our BJT has β=60 Ic will by
Ic=93.5uA*60=5.61mA. But if our bjt has β=100 then Ic=9.35mA and transistor will be working in saturation region. Because Icmax=V1/R2=10mA
npn transistor sizez
In circuit 1, there is no β so how you calculate Ic? V=IcR right?
bjt npn transistor
You look in the datasheet 2N4014
And then Hfe=β≈70 (Ic around 10mA)
bjt transistor β=100 multisim
if β = 70, the the Ic = 7mA.
But how about this? Can some one explain.[/b]
npn transistor calculation
Hmm, You know in a real word Ic will still have different value then it is in the simulation. Because we don't know the β of a 2N4014 we can only assume that β is smaller or equal 70.
In you're simulation the BJT is in saturation region because the β is larger the 100 and in the saturation the Ic=Ib*β don't hold anymore
In saturation Ic=(Vcc-vce(sat))/Rc
And that's why we use this circuit only as a switch.
If we want a linear amplifier we use this circuit
https://upload.wikimedia.org/wikipedia/commons/2/27/Common_Emitter_amplifier.png
Ic=[β*(Et-Vbe)]/(Rb+(β+1)*R4)
Et=[R2/(R1+R2)]*Vcc
Rb=R1||R2
|| - parallel Rb=(R1*R2)/(R1+R2)
And assume that Ic=1mA; Vcc=10V;β=70 and VR4=1V
VR3=(Vcc-VR4)/2=4.5V.
R3=4.5V/1mA=4.5K=4.7KΩ
R4=1V/1mA=1KΩ
R2=(VR4+Vbe)/(Iz)=5.1KΩ
Iz=5...30*(Ic/β)
R1=(Vcc-Vbe-VR4)/(Iz+Ib)=24KΩ
check this values in the simulation
vbe ic npn transistors
It is a horrible circuit that depends on the unknown actual value of the current gain or of the saturation voltage loss of the transistor.
Real transistor circuits have a voltage divider or negative feedback from the collector to the base for biasing. An emitter resistor is also used.
bjt npn data
Yes, in most cases. The purpose of the circuit hasn't been mentioned at all. So we don't even know, if saturation is intended (for a switch) or shall be avoided (for a linear amplifier). In the latter case, you probably try to achieve a particular operating point, but you didn't tell.
It didn't come clear, why Multisim uses the maximum current gain for 2N4014 rather than a typical value. But it's O.K. in so far, as a current gain of this size has to be considered. To check the circuit stability against parameter variations, the complete min to max range should be tested. Then the measures mentioned by Audioguru get important.
β, by the way, is usually the symbol for the small signal current gain and not identical to large signal value B, that is determining the operation point, altough the difference may be neglected in a rough estimation.
saturation region of bjt + wikipedia
Rumieus said:
Ib=V1/R1 = 0.1mA
Ic=V1/R2 = 10mA
β=100
Hello rumieus,
I am pretty sure you are confused now about all the formulat stuff.
Therefore, my recommendation:
At first, you should always have in your mind that transistor circuits are non-linear circuits - with the consequence that you carefully have to discriminate between static and dynamic (differential) resistances. Your circuit is a mixture of both - resistor as separate parts are static, but transistor pathes (for exampe between base and emitter) exhibit dynamic resistances. Therefore, you need characteristic curves from the data sheet for computing currents and voltages - or you can make suitable assumptions because some parameters are typical for all transistors.
As an example - to assume app. 0.7 volts between base and emitter for normal transistor operation as an amplifier.
And realize - perhaps with the help of a simplified transistor equivalent circuit diagram - that the transistor acts like a voltage controlled current source .
Without these basic considerations you cannot understand and analyze transistor circuits.
