+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Points: 808, Level: 6
    Join Date
    Aug 2008
    Posts
    Points
    808
    Level
    pwm vhdl
    how to implement VHDL code for PWM with frequency 1kHz and duty cycle of 20%
    •   Alt10th August 2008, 15:55
      advertising
  2. #2
    Super Moderator
    Points: 239,640, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,520
    Points
    239,640
    Level
    100
    vhdl pwm
    There are some points, that have to be considered before writing PWM code (respectively trying to copy some existing code):
    - the modulation scheme can be natural, regular symmetrical or regular asymmetrical sampling
    - PWM modulation input can be either relative (+/- 1 range) or absolute (requested output voltage). In the latter case, a bus voltage measurement has to be processed in the PWM generation. The method is particular useful for a multi-channel (3-phase or more) PWM.
    Generally, a ramp generator (mostly triangular), a comparator and optionally a sampler (for regular schemes) forms the PWM generator.
    1 members found this post helpful.
