+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Full Member level 6
    Points: 4,562, Level: 16
    Join Date
    Nov 2004
    Romania
    Posts
    382
    Points
    4,562
    Level
    16
    Coaxial resonator at 500MHz...1GHz
    I want to use a coaxial resonator as the IF filter at 500MHz. The resonator will be made of copper, with no special treatment, maybe not even silver plating.
    What selectivity can be expected from this?
    The frequency stability on the long term and with temperature variation of 10-40°C is good enough for an IF filter, or it needs to be tuned periodically?
    •   Alt4th August 2008, 14:18
      advertising
  2. #2
    Member level 4
    Points: 2,540, Level: 11
    Join Date
    Sep 2005
    china
    Posts
    72
    Points
    2,540
    Level
    11
    copper or brass will oxide in the air and the thin layer of oxide is not good conudctor.
    1 members found this post helpful.
    •   Alt4th August 2008, 14:54
      advertising
  3. #3
    Full Member level 6
    Join Date
    Nov 2004
    Romania
    Posts
    382
    Points
    4,562
    Level
    16
    Re: Coaxial resonator at 500MHz
    Thanks for reply.
    So silver plating is mandatory.
    What about frequency stability in time and with temperature variation if silver plating is done.
    •   Alt4th August 2008, 15:03
      advertising
  4. #4
    Full Member level 6
    Join Date
    Nov 2004
    Romania
    Posts
    382
    Points
    4,562
    Level
    16
    Re: Coaxial resonator at 500MHz...1GHz
    So far i read the chapter about coaxial resonators in Microwave filters - Matthaei, Jones.
    The diameter ratio should ensure a 76ohm impedance for minimum loss, and the structure will be silver or at least tin plated.
    What is the simplest software you recommend for simulation? The main problems remaining are:
    - temperature stability;
    - size of the magnetic coupling loops.
    By the way, this is not a commercial project, given the huge size of the filter.
