The explanation of Memristors ("memory resistors")
ok_box
Newbie level 6
Memristor
Memristors /memˈrɪstɚ/ ("memory resistors") are a class of passive two-terminal circuit elements that maintain a functional relationship between the time integrals of current and voltage. This results in resistance varying according to the device's memristance function. Specifically engineered memristors provide controllable resistance useful for switching current. The memristor is a special case in so-called "memristive systems", a class of mathematical models useful for certain empirically observed phenomena, such as the firing of neurons. The definition of the memristor is based solely on fundamental circuit variables, similar to the resistor, capacitor, and inductor. Unlike those more familiar elements, the necessarily nonlinear memristors may be described by any of a variety of time-varying functions. As a result, memristors do not belong to Linear Time-Independent (LTI) circuit models. A linear time-invariant memristor is simply a conventional resistor.
Source: https://en.wikipedia.org/wiki/Memristor
