+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Points: 923, Level: 6
    Join Date
    Dec 2007
    Posts
    Points
    923
    Level
    single op amp bandpass filter
    could anyone explain the working of the circuit, given in the link below-
    http://www.ecircuitcenter.com/Circui...B_bandpass.htm
    thanks in advance..
    •   Alt16th July 2008, 20:28
      advertising
  2. #2
    Advanced Member level 5
    Points: 39,631, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    narrow band pass filter using op-amp
    Quote Originally Posted by sarika
    could anyone explain the working of the circuit, given in the link below-http://www.ecircuitcenter.com/Circuits/MFB_bandpass/MFB_bandpass.htm
    The most simple explanation is as follows:
    1.) Very low frequencies are blocked by C2 and, therefore, cannot appear at the opampoutput;
    2.) Very high frequencies are fed back to the inverting opamp input with a factor of nearly "1" (via C1 and C2) - thus, they are amplified by nearly "zero".
    3.) As a consequence: the circuit has a bandpass property.
    4.) A somewhat more "theoretical" explanation is the folowing:
    The feedback network is, in principle; a "bridget-T" network which is known to exhibit a complex "zero". Due to the feedback action of the opamp the complex zero is transferred to a complex pole pair.
    1 members found this post helpful.
