+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Junior Member level 1
    Points: 1,892, Level: 10
    Join Date
    May 2008
    Germany
    Posts
    18
    Points
    1,892
    Level
    10
    Why do we use VCO and not fixed frequency oscillator?
    Excuse me, the oscillators with fixed oscillation frequency usually have relatively higher Q factor, so why do we use VCO?
    •   Alt11th July 2008, 10:39
      advertising
  2. #2
    Advanced Member level 1
    Points: 4,811, Level: 16
    Achievements:
    7 years registered
    Old Nick's Avatar
    Join Date
    Sep 2007
    Posts
    480
    Points
    4,811
    Level
    16
    Re: Why use VCO?
    The answer is in your question.
    One is controlled and one is fixed.
    •   Alt11th July 2008, 10:54
      advertising
  3. #3
    Full Member level 1
    Points: 1,738, Level: 9
    alexandr22061986's Avatar
    Join Date
    May 2007
    Ukraine
    Posts
    100
    Points
    1,738
    Level
    9
    Why use VCO?
    VCO used as a part of many circuits, for example PLL
    •   Alt12th July 2008, 11:28
      advertising
  4. #4
    Join Date
    May 2008
    Germany
    Posts
    18
    Points
    1,892
    Level
    10
    Re: Why use VCO?
    I think my question is not clear enough.
    I guess it is because tunable filter is not easily realized, we use VCO to get a fixed output frequency although the input signal is of different frequencies.
  5. #5
    Member level 3
    Points: 1,491, Level: 8
    Join Date
    Sep 2007
    Posts
    56
    Points
    1,491
    Level
    8
    Re: Why use VCO?
    I don't understand you, know.
    But i think Old Nick's answer is Ok.
  6. #6
    Full Member level 3
    Points: 2,275, Level: 11
    Achievements:
    7 years registered
    Join Date
    Oct 2007
    Hyderabad India
    Posts
    151
    Points
    2,275
    Level
    11
    Why use VCO?
    totally application specific
    •   Alt25th July 2008, 11:42
      advertising
  7. #7
    Member level 1
    Points: 2,334, Level: 11
    rudane's Avatar
    Join Date
    Mar 2004
    Posts
    39
    Points
    2,334
    Level
    11
    Re: Why use VCO?
    Well I can give one example for you ... you have to understand mixing and intermediate frequencies to get it:
    I've just worked on a project where we used a magnetron as a source. The frequency drifts with temperature changes. The source is mixed a few times and filtered (A SAW filter, very high Q). If the source drifts too much then when we mix, the resulting signal does not make it through the passband. The only thing we could do was design a PLL with a VCO so we could change intermediate frequencies, which would bring the resultant back into the passband.
    Hope this isn't too complicated.
    1 members found this post helpful.
