Need help with building a pal programmer
saltlake
Junior Member level 2
pal programmer
HI!
I need a pal as address decoder, so I would to build a pal (palce) programmer (a pal programmer is too expensive to buy). I can’t find technical doumentation about pal programming. Can you help me? I don’t want to use a JEDEC file, but, if it’s not too hard, I would to use a custom file to download in the pal by a microcontroller.
Thank you.
Re: pal programmer
I just find one, you can make it by yourself.
pal programmer
I click the link above and try to use PALASM4 V1.5
to create JEDEC file. but unsuccessful. i already install PALSAM and with complie successful. why still can not create JEDEC file?
Re: pal programmer
Hi all
Galblast can not program PAL devices.
pal programmer
I have a .abl file and I using PALCE20V8 chip, I want to create JEDEC file, which software should be used? Thnaks!
