+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Member level 3
    Points: 1,307, Level: 8
    Join Date
    Feb 2008
    Posts
    56
    Points
    1,307
    Level
    8
    what type of resistor suitable for filtering purpose?
    i need to create a low pass filter for an assignment.
    there are many type of resistor based on their element for example ceramic, carbon film, alloy etc.
    my lecturer mentioned that some resistor elements are suitable for filter circuit while some not.
    mind to tell me which are suitable and which aren't?
    thanks in advance. :D
    •   Alt6th July 2008, 17:23
      advertising
  2. #2
    Advanced Member level 5
    Points: 39,631, Level: 48
    Achievements:
    7 years registered
    LvW's Avatar
    Join Date
    May 2008
    Germany
    Posts
    5,680
    Points
    39,631
    Level
    48
    Re: what type of resistor suitable for filtering purpose?
    Well, it´s not so easy to answer. As you probably know - everything in analog electronics is a compromise. The resistor selection (as well as selection of all other parts) depends on your requirements resp.the order of requirements. That means: which property of the filter is most important (tolerance, temp-co, cost, reliabilty, parasitics, ....)?
    In this context, it is important to know the frequency range of your filter.
    In general, one can say that metal film and wirewound resistors have good tolerances and and a low temperature coeff. As metal types are cheaper they are widely utilized in filter techniques. However, wirewound types are bad as far as parasitics are concerned.
    •   Alt6th July 2008, 17:37
      advertising
  3. #3
    Points: 12,565, Level: 26
    Borber's Avatar
    Join Date
    Jan 2000
    on third flor
    Posts
    1,602
    Points
    12,565
    Level
    26
    Filter transfer characteristics depend allso on resistor parasitics. First of all it is series inductance and second parallel capacitance. Other resistor parameters have influence on filter stability over temperature, time etc.
    I think your main task is not filter design but study of different resistor type properties.
    •   Alt7th July 2008, 04:51
      advertising
  4. #4
    Points: 809, Level: 6
    Join Date
    Jul 2008
    red planet
    Posts
    Points
    809
    Level
    hi!
    you can use wire wound type resistor in filtering purposes ,cause it is more lager than a carbon type resistor and cannot be hardly be burned out 'you can use 5 watts or larger than that, you can also uae carbon type if it is 1 in size, but i assuare you that wirewound type is more usefull!
