+ Post New Thread
Results 1 to 6 of 6
  1. #1
    Full Member level 1
    Points: 1,810, Level: 9
    senaydud's Avatar
    Join Date
    Jun 2008
    Posts
    112
    Points
    1,810
    Level
    9
    Calling Simulink blocks using MATLAB code
    Hi people,
    There are Simulink blocks in the Matlab. How can I call them and use them in my *.m file. For instance "Phase-Locked Loop" block in the "Communications Blockset" is something that I need to call in my Matlab code.
    •   Alt4th July 2008, 23:31
      advertising
  2. #2
    Member level 3
    Points: 2,657, Level: 12
    Join Date
    Aug 2005
    Posts
    56
    Points
    2,657
    Level
    12
    Re: Calling Simulink blocks using MATLAB code
    With:
    sim('simulink_model_name');
    Note: no .mdl in the 'simulink_model_name'
    1 members found this post helpful.
    •   Alt23rd July 2008, 19:42
      advertising
  3. #3
    Full Member level 1
    senaydud's Avatar
    Join Date
    Jun 2008
    Posts
    112
    Points
    1,810
    Level
    9
    Thanks carl for your reply,
    You know there are some pre-defined blocks in the simulink which are not available as a Matlab function, such as the "PLL" block. I haven't designed any circuit using simulink and what I want to do is just to call these blocks in my *.m file.
    •   Alt23rd July 2008, 22:14
      advertising
  4. #4
    Member level 3
    Join Date
    Aug 2005
    Posts
    56
    Points
    2,657
    Level
    12
    Then you just build a simulink model file with this pll block and simulink "Workspace" in/out ports, then call this model in your Matlab program as I indicated.
  5. #5
    Full Member level 1
    senaydud's Avatar
    Join Date
    Jun 2008
    Posts
    112
    Points
    1,810
    Level
    9
    That would work as a thing which may also mean it might be the only way to do it. thanks carl, that deserve a click on the help button ))
    •   Alt24th July 2008, 23:20
      advertising
  6. #6
    Newbie level 1
    Points: 517, Level: 4
    Join Date
    Jan 2010
    kanyakumari
    Posts
    Points
    517
    Level
    hi i am clara..doing M.E project on SVM algorithm 4 a multilevel inverter...i dont have any idea regarding that project..plz can anyone help me..
