+ Post New Thread
Results 1 to 2 of 2
  1. #1
    Junior Member level 3
    Points: 1,965, Level: 10
    Join Date
    Feb 2008
    Posts
    30
    Points
    1,965
    Level
    10
    Question regarding Miller Capacitance
    The attached graph is from W. Sansen book, page 189 and I am a bit confused, on one hand, the text in the book seems to suggest that the rule of thumb is that Cc should be smaller than CL, on the other hand, the gm chart seems to indicate that the optimum Cc is about 4x of CL, my question is that what is the primary consideration to determine the Cc value, and what is the major benefit to have gm1=gm6 as the chart suggests?
    Also, if Cc can be so optimally calculated from Gm curves, why do we have to make any assumptions to begin with?
    •   Alt24th June 2008, 19:08
      advertising
  2. #2
    Full Member level 5
    Points: 3,271, Level: 13
    Achievements:
    7 years registered
    amitjagtap's Avatar
    Join Date
    Jan 2007
    Posts
    304
    Points
    3,271
    Level
    13
    Primary concern to decide value of Cc is the bandwith and required phase margin. and major benefit of gm1=gm6 is the improved stability. cutthe draw back is reduced bandwith comparatively.
