+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 6
    Points: 1,813, Level: 9
    Achievements:
    7 years registered
    Join Date
    Aug 2006
    Posts
    13
    Points
    1,813
    Level
    9
    A kind of tuning circuit in Gm-C filter
    Hi, all:
    I design tuning circuits for gm-c filter to compensate the gm's variation due to process,temperature and aging.
    My reference is form the book"Wireless.Communication.Circuits.And.Systems", and details in accessories. But I have some questions below,please help me check them.
    1.The Gm cell in the “Tuning circuits” (accessories) is single-ended or should be balanced ,just like those gm cells in filter ?
    2. I was confused by those sentences “The arrangement uses a control loop comprising a skewed ‘diode-connected’ transconductor −G0 which generates a quiescent voltage which is offset from that of the reference transconductor” What does “offset” mean? How to explain it ?
    Thanks!!
    •   Alt16th June 2008, 16:00
      advertising
  2. #2
    Advanced Member level 1
    Points: 3,875, Level: 14
    jecyhale's Avatar
    Join Date
    Feb 2008
    China
    Posts
    403
    Points
    3,875
    Level
    14
    Re: A kind of tuning circuit in Gm-C filter
    Hi, friend
    1, I think you should use the same Gm cell as that in filter.
    In fact, I use the Gm cell in filter as a part of tuning circuit. So balanced one should be used.
    2, I think 'offset' is a DC difference. You should refer to the whole design to explain it. But the purpose of it is to make sure the gm cell is same with that in filter.
    Good luck
    1 members found this post helpful.
    •   Alt17th June 2008, 03:04
      advertising
  3. #3
    Newbie level 6
    Achievements:
    7 years registered
    Join Date
    Aug 2006
    Posts
    13
    Points
    1,813
    Level
    9
    Hi,jecyhale
    Thanks for your kind help! The whole design reference paper is attached .
    I designed the tuning circuits based on single-end gm cell, You said this tuing circits should use balanced gm cell , I think this will be better for "master-slave" tuning.
    But how to transfer this single-end tuning to balanced one?
    1. The inverter can be replaced by comparator ?
    2. which kind of tuning circuits have you used in practice gm-c filter design ?
    Is it using PLL ?
    Thanks!
