+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Full Member level 5
    Points: 4,086, Level: 15
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Posts
    289
    Points
    4,086
    Level
    15
    type of antenna used in mobile phones
    hi
    i am just wondering what type of antennas are being used in the commercial phones e.g nokia , samsung and sony ericsson
    where can i find the related information and pictures showing the antenna type
    regards
  2. #2
    Advanced Member level 5
    Points: 33,613, Level: 44
    ckshivaram's Avatar
    Join Date
    Apr 2008
    villingen (Germany) / Bangalore
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    nokia handset antenna
    All mobiles use dipole antenna as they are capable of capturing signals from 360degrees. Phone uses signal booster for enhancing the low signal, which we dont get in general purpose modem used in some projects.
    1 members found this post helpful.
  3. #3
    Full Member level 5
    Points: 3,796, Level: 14
    Achievements:
    7 years registered
    balaguru thavamani's Avatar
    Join Date
    Nov 2006
    Posts
    245
    Points
    3,796
    Level
    14
    antennas used in mobile phones
    •   Alt16th June 2008, 04:35
      advertising
  4. #4
    Full Member level 5
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Posts
    289
    Points
    4,086
    Level
    15
    nokia basic handsets with antenna
    hi ckshivaram
    i dont think so that dipole is being used in modern handsets nowadays. they were used in earlier handsets where u can see the antenna protruding from the top.
    nowadays all handsets use internal antennas like pifa
    balaguru thavamani thanks for posting the link. i have checked it and as i mentioned in my first post , PIFA is the most widely used antenna in handsets
    but can you post any other information about the antennas used in latest nokia handsets or samsung
  5. #5
    ckshivaram's Avatar
    Join Date
    Apr 2008
    Posts
    5,070
    Points
    33,613
    Level
    44
    Blog Entries
    antenna used in nokia mobiles
    Microstrip patch antennas are commonly used in mobile communications terminals due to their many attractive
    features, such as simple structure, low production cost, light weight, and robustness. Dual-frequency antenna elements
    are required, as today’s standard mobile terminals operate in two frequency bands, e.g. GSM900/GSM1800 in Europe.
    It is desirable to have more universal phones that operate in multiple systems around the world, but the inherently
    narrow impedance bandwidth of patch antennas combined with the restricted volume for the antenna element limit their
    applicability in multiband phones.
    http://lib.tkk.fi/Diss/2004/isbn9512273810/article9.pdf
    •   Alt16th June 2008, 12:43
      advertising
  6. #6
    Advanced Member level 2
    Points: 6,074, Level: 18
    Join Date
    Jan 2007
    Sweden
    Posts
    603
    Points
    6,074
    Level
    18
    antenna used by nokia
    Samsung and Nokia do use PIFA for all wide band antennas (850, 900, 1800,1900 MHz). Here is picture from a Samsung U600:
    h**p://www.ethertronics.com/photo_gallery/10/
    Nokia N95:
    h**ps://fjallfoss.fcc.gov/oetcf/eas/reports/ViewExhibitReport.cfm?mode=Exhibits&RequestTimeout =500&calledFromFrame=N&application_id=640965&fcc_i d='PDNRM-321'
    Main difference compared to older PIFA antennas is improved design to cover more bands with smaller and slimmer size. None of them have ever been using dipoles as antenna in a mobile phone due to poor function in available space. Older phones with external antennas have been more or less shortened monopoles.
    Both Nokia and Samsung makes singel band phones (2100 MHz) with an embedded monpole antenna.
    This type of antenna can get enough height above ground to work reasonable well even as embedded due to the short wave lengt and relative narrow band.
    Have never seen a patch as phone antenna but ceramic patches are sometimes used as gps or bluetoth antennas inside a phone.
    •   Alt16th June 2008, 19:52
      advertising
  7. #7
    Full Member level 5
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Posts
    289
    Points
    4,086
    Level
    15
    antenna used in nokia handsets
    thanks E Kafeman for your insightful link and helpful comments on modern handset antennas
    regards
  8. #8
    Points: 15,234, Level: 29
    khouly's Avatar
    Join Date
    Oct 2003
    EGYPT
    Posts
    2,368
    Points
    15,234
    Level
    29
    what type of antennais used in cell phones
    also fractal antennas are used ,
    check
    http://www.fractus.com/
    khouly
  9. #9
    Full Member level 2
    Points: 2,417, Level: 11
    Achievements:
    7 years registered
    Join Date
    Feb 2008
    Colorado, USA
    Posts
    128
    Points
    2,417
    Level
    11
    where are anttennas present in nowdays mobile
    fractus antennas are not used much any more mostly PIFA (shorted Patch) are used my company has done several tests on the fractus idea we have found that even though they are well matched they don't radiated as efficiently as other antenna designs (but they are small)
  10. #10
    Full Member level 5
    Achievements:
    7 years registered
    Join Date
    Jul 2006
    Posts
    289
    Points
    4,086
    Level
    15
    design dipole antenna ceramic monopoles
    yes i agree with b4bb4ge . i dont know of any handset manufacturer which is using fractal antennas.
    regards
  11. #11
    Member level 1
    Points: 2,241, Level: 10
    akrcal's Avatar
    Join Date
    Aug 2006
    Posts
    32
    Points
    2,241
    Level
    10
    nokia handsets+ antenna type
    Generally people use microstrip patch antenna. For better idea you can have a look at the attached file.
  12. #12
    Advanced Member level 3
    Points: 9,181, Level: 22
    Join Date
    Sep 2003
    Posts
    868
    Points
    9,181
    Level
    22
    nokia fractal antenna
    Hi, all:
    I believe many handset antennas are using various kinds of PIFA antennas and modified monopoles. The 1st handset without monopole was from Nokia some years ago. I helped them to model it correctly on IE3D.
    Some designers are also modified monopoles. A well-known antenna designer from SonyEricsson designed a multi-band antenna using modified monopole. He said the antenna he designed was used by more than 100 million handsets. Interestingly, he told me he was using IE3D on it.
    Another interesting fact is that some handset may look like they have a monopole there. However, it s a fake one. Designers want to make a fake one there so that users may feel more comfortable on the handset because they got used to the handsets with some type of monopole antenna. Regards.
    •   Alt21st June 2008, 17:40
      advertising
  13. #13
    Newbie level 6
    Points: 877, Level: 6
    Join Date
    May 2008
    Posts
    11
    Points
    877
    Level
    microstrip patch antenna for mobiles
    at present, some mobile phones use PIFA and some use monopole, because now many phones are small and thin, the PIFA antenna can not satisfy this requirement, so many thin moble phones use monopole antenna.
