What is an insulator and what are its functions?
Re: Insulator
An **broken link removed** is a material that resists the flow of electric current. It is an object intended to support or separate electrical conductors without passing current through itself. An insulation material has atoms with tightly bonded valence electrons. The term electrical insulation has the same meaning as the term dielectric.
Some materials such as silicon dioxide or Teflon are very good electrical insulators. A much larger class of materials, for example rubber-like polymers and most plastics are still "good enough" to insulate electrical wiring and cables even though they may have lower bulk resistivity. These materials can serve as practical and safe insulators for low to moderate voltages (hundreds, or even thousands, of volts).
