seanigang
Newbie level 1
rtlcompiler delete_unloaded_seqs
Hi! During synthesis using RTL Compiler, combinational loops were found in my design. As what the log file says, the tool disabled them, deleted several hierarchical instances, then added loop breakers. I've simulated the generated netlist and found errors on the output waveform. Now, my questions are :
-What happens to the actual hardware/schematic when these combinational loops were disabled? Does the tool deletes signals,modules,instances included in the combinational loop?
-Any tips on how to make these things right?
Any help is deeply appreciated. TIA
