interfacing two I2C - how to convert SPI do I2C?
sonia sharma
Newbie level 6
INDIA
interfacing
Hi all,
I am working on aproject where i have to interface two I2C.but at the microcontroller side i have only SPI.
Kindly suggest me a solution how can i convert SPI to I2C as soon as possible.
Thanks
Sonia
Re: interfacing
please specify which IC you want to interface. what is the problem in using SPI in that case. Are you specific in using I2c only
Re: interfacing
A MARVELL controller having I2C interface act as a master,which i have to interface with MAXIM IC having SPI ACT AS A SLAVE.
Added after 7 minutes:
how can i make an interface between SPI and I2C :?:
interfacing
why dont use PIC 16F877A
it have all you need
interfacing
Hello,
SPI and I2C are two fundamentally different bus systems. You can probably implement a software I2C slave.
interfacing
If u have an I2C device then your best option is to use a software implimentation of the I2C protocol.
It's not difficult to do!
Re: interfacing
I2C and SPI are different bus interfaces.
Make a SW implementation, you can find sw examples on internet
Check this websites:
www. Embedded.com and look for tis article "Introduction to I2C"
In attach you can find the I2C bus specification
    V
