+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Advanced Member level 3
    Points: 8,260, Level: 21
    Join Date
    Nov 2006
    Posts
    982
    Points
    8,260
    Level
    21
    tlc277p datasheet
    i highly appreciated if someone upload the datasheet of TLC277P
    can this chip operate with 2.5 v supply voltage ?
    for this i need its datasheet
    •   Alt16th May 2008, 04:42
      advertising
  2. #2
    Junior Member level 3
    Points: 1,203, Level: 7
    Join Date
    Oct 2007
    Posts
    25
    Points
    1,203
    Level
    7
    tlc277p
    Dual Precision Single Supply Operational Amplifier
    is this what it is you might have seen similar models like
    TLC277IP
    TLC277CP
    by texas instruments
    attached is the datasheet of TLC277IP
    it might help
    •   Alt16th May 2008, 04:57
      advertising
  3. #3
    Join Date
    Nov 2006
    Posts
    982
    Points
    8,260
    Level
    21
    datasheet tlc277p
    i think TLC277P =/= TLC277IP ,TLC277CP .
    it should be different
    •   Alt16th May 2008, 07:20
      advertising
  4. #4
    Super Moderator
    Points: 239,566, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    41,505
    Points
    239,566
    Level
    100
    Re: need datasheet of TLC277P
    Did you ever read the datasheet respectively the TI product information page? They tell in detail about the used type coding. Actually I or C postfix is for temperature range, P is for DIP package. As the supply voltage specification is also temperature dependant, there may be smaller difference, however none of TLC277 variants is specified for 2.5V operation, I think.
