+ Post New Thread
Results 1 to 18 of 18
  1. #1
    Full Member level 5
    Points: 2,981, Level: 12
    Join Date
    Nov 2007
    Posts
    263
    Points
    2,981
    Level
    12
    not gate using mux
    Can anyone send me a material on NOT ,AND ,XOR,XNOR,NAND,INVERTER using MUX ???
    Plz its urgent send me a material i will give u 20 points
  2. #2
    Junior Member level 2
    Points: 1,316, Level: 8
    Join Date
    Mar 2008
    Hyderabad, India
    Posts
    23
    Points
    Level
    8
    nand using mux
    Realization of GATE USING MUX
    If any one finds wrong in this reply me
    If u other design share with us
    with regards
    khalandar basha
    basha_vlsi@yahoo.co.in[/img]
    8 members found this post helpful.
  3. #3
    Full Member level 5
    Join Date
    Nov 2007
    Posts
    263
    Points
    2,981
    Level
    12
    mux as inverter
    thanks
    2 members found this post helpful.
    •   Alt15th May 2008, 06:47
      advertising
  4. #4
    Banned
    Points: 4,334, Level: 15
    Join Date
    Jan 2007
    Posts
    208
    Points
    4,334
    Level
    15
    mux logic gates
    hii basha u missed Nor gate
  5. #5
    Join Date
    Mar 2008
    Hyderabad, India
    Posts
    23
    Points
    Level
    8
    inverter using mux
    hi vlsi technolgy
    i hope i designed not gate correctly.
    hi venkat_kvr
    as he didn't mentioned abt nor gate i didn't draw
    and ur's design for nor gate is correct yaar
    and thanks for helping out
  6. #6
    Full Member level 1
    Points: 1,509, Level: 8
    Join Date
    Feb 2007
    Posts
    97
    Points
    1,509
    Level
    8
    nand inverter
    Sorry but really i cant realize what is the advantage of using mux to design those logic gate ? With respect to digital, again you have to use gates to build mux, and with respect to analog surely the number of transistor you are going to use to build a logic gate by mux will more than the no you have to spend to directly build a gate.
    Those above designs are effective in which aspect ? Resolution ( i mean true replica of output waveform ) ?
  7. #7
    Points: 7,630, Level: 20
    Achievements:
    7 years registered
    AdvaRes's Avatar
    Join Date
    Feb 2008
    At home
    Posts
    1,166
    Points
    7,630
    Level
    20
    xnor using nand
    Quote Originally Posted by atena
    You're rigth but this kind of questions are very usefull for people preparing themselves for interviews.
  8. #8
    Member level 4
    Points: 1,349, Level: 8
    Join Date
    May 2008
    Munich, Germany
    Posts
    74
    Points
    1,349
    Level
    8
    instrucciones nor, xor, and,in, out, not
    Quote Originally Posted by AdvaRes
    This is not only useful for interviews, but sometimes has real use when doing a metal fix.
    Some designers like to combine muxes as spare cells. If in later stage you need to add logic, you gotta be able to generate your logic from mux structures. Therefore understanding these implementations is important.
    Actually one can also use muxes to create memory elements like latches and flip flops. One of my blog posts dealt exactly with that issue, check it out here:
    http://asicdigitaldesign.wordpress.c...-10-mux-logic/
    hope this helps,
    ND.
    •   Alt19th May 2008, 16:25
      advertising
  9. #9
    Newbie level 1
    Points: 703, Level: 5
    Join Date
    Jan 2009
    Posts
    Points
    703
    Level
    mux nand
    thanks a lot..
    1 members found this post helpful.
  10. #10
    Newbie level 5
    Points: 1,288, Level: 8
    Join Date
    Aug 2008
    New York, US
    Posts
    9
    Points
    Level
    8
    implement or gate and and gate using mux
    I feel we should not mix the advantage of implementation of logic in CMOS comparing the same with implementation of logic using gates.
    Each has its own importance. The simple implementation of logic using gates (as we realize mux logic using gates) helps a clearer understanding while the reduced implementation in CMOS provides faster operation (in ns) and smaller area too by reducing the transistor count. Finally it is a logic equation which is being realized.
    Just imagine the no. of transistors required to implement XOR gate using individual gates and then using mux ... the difference is clearly visible.
    Regards,
    Anuj.
  11. #11
    Achievements:
    7 years registered
    AdvaRes's Avatar
    Join Date
    Feb 2008
    At home
    Posts
    1,166
    Points
    7,630
    Level
    20
    how to use a mux as an inverter
    Quote Originally Posted by anuj.joamon
    Regards,
    Anuj.
    You're right, but such questions are asked in interviews.
  12. #12
    Newbie level 2
    Points: 570, Level: 5
    Join Date
    Oct 2009
    hyd
    Posts
    Points
    570
    Level
    Re: AND,NOT,OR,XOR,XNOR,NAND,INVERTER using MUX
    and≡
    take two cases i.e for a==0,a==1;('a' is a selected line for 2:1mux)
    take 0 and b as inputs to mux
    if(a==0)
    out =0;
    elsif(a==1)
    out=b;[/img][/code]
  13. #13
    Newbie level 2
    Points: 686, Level: 5
    Join Date
    Mar 2009
    Posts
    Points
    686
    Level
    thanks guys, does anyone know how to use mux4 to generate Y=a(~b)(~c)+(~b)(~C)+(~a)(~c)...
    that will be helpful..
    Added after 1 minutes:
    FYI just only one mux4
  14. #14
    Newbie level 1
    Points: 659, Level: 5
    Join Date
    Apr 2009
    Posts
    Points
    659
    Level
    same thing i can get for CMOS i.e. AND,NOT,OR,XOR,XNOR,NAND,INVERTER using CMOS
  15. #15
    Newbie level 2
    Points: 469, Level: 4
    Join Date
    May 2010
    US
    Posts
    Points
    469
    Level
    Hi all,
    I am a little bit confused on the OR gate.
    The OR gate boolean expression is Y = BA' + AA => B(1-A) + A => A + B - AB. Shouldn't the OR gate boolean expression be A + B ? However, the definition of OR operation is A U B = A + B - AB. Did I miss anything? Correct me if I am wrong.
    Thank you.
    •   Alt4th May 2010, 00:49
      advertising
  16. #16
    Member level 5
    Points: 1,693, Level: 9
    Join Date
    Jan 2008
    Posts
    83
    Points
    1,693
    Level
    9
    Just to avoid confusion:
    B(1-A) = B•(1-A)
    which means "B is *dependent* on the inverse of input A".
    Meaning, we only need to check B input if A=0.
    B(1-A) + A should not be written as (B + A - A•B) to avoid confusion since we are not dealing with normal maths but Boolean logic.
    Comparatively, (B + A•B) can be reduced to B using Boolean logic, i.e.:
    B + A•B = B
    but this is wrong in conventional maths.
    So, how do we define the statement (B - A•B) in words for Boolean logic?
    BTW, (1 - A•B) would define the NAND logic of inputs A & B.
    Best regards.
  17. #17
    Newbie level 2
    Join Date
    May 2010
    US
    Posts
    Points
    469
    Level
    I guess in this case the boolean multiplication is not like algebra multiplication. Some other cases, like
    a--
    b--OR--
    c-------AND-- Y
    will get Y = (a+b)•c = ac + bc.
    Is there a rule indicates when the boolean multiplication cannot be used as algebra multiplication? How do we derive the b•(1-a)+ a to a + b as the OR gate boolean expression?
    Thanks.
  18. #18
    Member level 5
    Join Date
    Jan 2008
    Posts
    83
    Points
    1,693
    Level
    9
    I think we just opened a can of worms !^_^ .
    What I was trying to say was, don't expand minus signs.
    Safer to leave 1-XXXXX as 'inverse of'.
    Of course some one out there might be able to make sense of A-C.
    Best regards.
