+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Points: 1,478, Level: 8
    Join Date
    Feb 2005
    Posts
    Points
    1,478
    Level
    8
    LVS for digital design
    I am designing a mixed-signal circuit
    the digital part is implemented using Verilog, synthesized with DC and the backend is done with SOC encounter, now the problem is how to do LVS
    The standard cell vender gives us a CDL file for LVS, in which it defines the sizes of transistors and their connections, but using simplified PMOS/NMOS model files (can't work with Spectre/SPICE, just show the transistor sizes).
    I have the GDS file and also the verilog source code, is there anyone know how to utilize the CDL file provided as "LVS netlist" for LVS? Btw, I am using Calibre.
    Thanks and any sugguestion is appreicated.
    •   Alt7th May 2008, 03:37
      advertising
  2. #2
    Member level 3
    Points: 1,543, Level: 8
    Join Date
    Apr 2008
    Posts
    59
    Points
    1,543
    Level
    8
    Re: LVS for digital design
    It seems that you need to you calibre to convert verilog netlist to CDL files and write a file that includes digital netlist and analog netlist. Then you can run LVS.
    •   Alt7th May 2008, 09:31
      advertising
  3. #3
    Join Date
    Feb 2005
    Posts
    Points
    1,478
    Level
    8
    Thanks for the kind help~~~
    Quote Originally Posted by zhongdg
    •   Alt7th May 2008, 17:15
      advertising
  4. #4
    Full Member level 3
    Points: 2,225, Level: 10
    layoutmaster's Avatar
    Join Date
    Mar 2008
    Posts
    181
    Points
    2,225
    Level
    10
    I guess zhongdg is right. See the following page.
    http://64.233.169.104/search?q=cache...lnk&cd=1&gl=ar
    Hope this helps
