rom/ram implementation ..
prashant_sharma
Newbie level 5
hello all,
i would like to know that can we create the rom/ram as an array using the following:
first an array say rom:
type rom is array (0 to 8) of st_logic_vector(7 downto 0);
and the create signals , of this type...and the choose values to be stored in it ...
But my question is.. would it be synthesizable??
thanks
Added after 12 minutes:
that rom is 0 to 4 and 7 down to 0
i don kbow where that smiley came from :p
Many synthesis tools will infer ROMs and RAMs from your HDL code, if your target device supports it. You may need to write your HDL code in a certain way to get the desired results. Check your synthesis user manual. For example, the "HDL Coding Techniques" chapter in the Xilinx XST User Guide.
When you post or edit a message, look near the bottom of the page for a checkbox, "Disable Smilies in this post".
