PanosB_GR
Junior Member level 2
I would like to simulate the electron current flow that passes through a pin-cathode and a grounded anode plane in the case of a spark discharge.
Does anybody have any hint on how to properly set up the particle source on the pin tip and what would be the best parameters for the model?
I do set up two potentials, the -V of the cathode (e.g -100kV) and 0 V for the ground plane and activate them as a tracking field.
A parameter that I would like to include is a DC-like emission process, for instance a given (estimated) current amount that would be emitted from the cathode.
