How to read MP3 files on SD card ?( DE2 board mp4 player project)
nindra
Newbie level 3
hi everybody,
i am just a newbie. Now, i am working a MP3 player project.I use DE2 Board from Altera. I store the MP3 files in a SD Card. I am confuse how to read the files.Plizzz give me an Advice.THx
de2 sd card
the design board should have some kind of reference application or demo in which you can take what you want to build your own design.
look at the accompanying datasheets and documents.
building an mp3 player on the altera de2 board
I have read the reference. that is a demo program to read a music files with WAV extension.I also read at another literature that VHDL can't process a MP3 files. We must change the file to binary format First,like .bin. Is that correct?
nios ii mp3 wav
I don't know if the board has the SD protocol and filesystem implemented. If not, you need to write your own:
- first you need to communicate at low level with the SD card i.e. reading&writing 512B sectors; you can use the simple and slower SPI interface, or implement the complete SD interface;
- then implement the FAT16/FAT32 filesystem.
Playing MP3 files is very difficult if not using a library, it involves lots of signal processing, a lot harder than WAV, which has info about the audio samples. For MP3 you may need additional libraries and IP blocks.
de2 vhdl audio
Eugen, can u explain to me about FAT16 and FAT32 filesystem??Cuz i don't get the point. Is it possible to read data from flash memory without using NiosII??
Added after 28 minutes:
can i play WAV file that i store in onboard flash memory without using a NiosII?cuz i read the example that explain that we can use te AUDIO_DAC file to read the flash memory.
