How to get 24V/4amps DC source and 12V/150-200mA DC source
vinothtnt
Junior Member level 1
i need 24V,4amps dc source.can anybody help me
Re: 24v,4amps dc source
I think your question is not clear.
For what application you need 24V/4A DC source.
you want to convert 110V AC to 24V DC with 4A load current capability.
i need 24V/4amps DC source and 12V/150-200mA Dc source can tell me how can i get this
You can use a variable Lab dc power supply to generate 24Vdc @ 4Amps or you can build yourself a linear power supply if you have some time.
If you want a compact & light weight solution then go for switch mode dc power supply which will be cost efficetive & available off the shelf.
If you want to built your own power supply go to www.powerint.com
They have some easy to use chips.
