gauz
Junior Member level 3
Hi, all
there are several clock in my design, here is two case for comparison:
1, Input only one clock,'clk_in', and all other clocks are derived from this input clock by DCMs, specify only the input clock period, the design report HOLD time violation.
2, Input all clocks from external , and no DCM is used, specify the all the input clock period respectively, and the result reports no timing violations.
After compared the timing reports of the two cases, I found the clock skew in the first case is much bigger then the second case, what's the problem? how should I set the constraints in the first case?
Thanks
Thanks
