VHDL Loop error: Process Statement must contain only one Wait Statement
syyang85
Newbie level 3
This is a typical counter which counts until 31 with every clock coming in
but im havin this error
Error (10398): VHDL Process Statement error at count31.vhd(27): Process Statement must contain only one Wait Statement
why can't i have more than more than 1 wait statement in the process, if not how am i ever to loop it?
any ideas?
library IEEE;
use IEEE.STD_LOGIC_1164.all;
use IEEE.STD_LOGIC_ARITH.all;
use IEEE.STD_LOGIC_UNSIGNED.all;
entity COUNT31 is
port ( CLK: in std_logic;
COUNT: out integer);
end COUNT31;
architecture behav_COUNT of COUNT31 is
begin
P_COUNT: process
variable intern_value: integer;
begin
intern_value:=0;
while (intern_value<31) loop
wait until CLK='1';
intern_value:=intern_value + 1;
COUNT <= intern_value;
end loop;
end process P_COUNT;
end behav_COUNT;
when i try to change wait until CLK='1'; to if (CLK'event and CLK='1') then
It gave me warning of exceeding 10,000 iteration.
Why it wont exit the loop when the condition of (intern_value<31) is fulfilled?
Re: VHDL Loop error
Instead of giving verbose explanations, why the code won't be synthesizable, may I simply ask, what you wan't to achieve?
Re: VHDL Loop error
Actually I was experimenting with the Loop statements.
Actually, im building a data acquisition module for a camera
Here's the scenario, typical camera have vsync,href,pclk and 8-bits data.
vsync represents new frame
href represents new line
pclk represents new pixel
I would like to capture the first 50x50 pixels of the frame and another frame after the 60th frame.
All I need is two frames.
I'm getting this error
Error (10519): VHDL Type or Variable Declaration error at camera.vhd(44): bounds of type or variable range must have same type
Error (10515): VHDL type mismatch error at camera.vhd(44): integer type does not match string literal
Here my code:
LIBRARY ieee;
USE ieee.std_logic_1164.all;
USE ieee.numeric_std.all;
use ieee.std_logic_arith.all;
use ieee.std_logic_unsigned.all;
ENTITY camera IS
PORT
start : IN STD_LOGIC;
pixel : IN STD_LOGIC_VECTOR(7 DOWNTO 0);
clk : IN STD_LOGIC;
vsync : IN STD_LOGIC;
href : IN STD_LOGIC;
pclk : IN STD_LOGIC;
pixel_out : OUT STD_LOGIC_VECTOR(7 DOWNTO 0);
reference : OUT STD_LOGIC
END camera;
ARCHITECTURE behave OF camera IS
SIGNAL frame_count : STD_LOGIC_VECTOR(6 DOWNTO 0);
SIGNAL line_count : STD_LOGIC_VECTOR(6 DOWNTO 0);
SIGNAL pixel_count : STD_LOGIC_VECTOR(6 DOWNTO 0);
BEGIN
PROCESS (vsync, href, pclk)
BEGIN
IF start='1' THEN--------------------------------------------STARTS THE CAPTURING SEQUENCE
frame_count <= (OTHERS => '0');
line_count <= (OTHERS => '0');
pixel_count <= (OTHERS => '0');
IF(vsync'EVENT AND vsync = '1' ) THEN
FOR frame_count IN "0000000" TO "111100" LOOP
frame_count <= frame_count + "0000001"; -------------COUNTS FRAME UNTIL 60
IF(href'EVENT AND href = '1' ) THEN
FOR line_count IN "0000000" TO "110010" LOOP
line_count <= line_count + "0000001";---------COUNTS LINE UNTIL 50
IF(pclk'EVENT AND pclk = '1' ) THEN
FOR pixel_count IN "0000000" TO "110010" LOOP
pixel_count <= pixel_count + "0000001"; --COUNTS PIXEL UNTIL 50
pixel_out<=pixel;-----------------------------OUTPUTS THE PIXEL DATA
reference<='1';------------------------------FOR SAVING THE DATA INTO RAM PURPOSES
END LOOP;
END IF;
END LOOP;
END IF;
END LOOP;
END IF;
ELSE
null;
END IF;
END PROCESS;
END behave;
Re: VHDL Loop error
Yes, I see what you are intending. But it doesn't work this way. Taking just a snippet from code:
END LOOP;
END IF;
First there is a syntax error. line_count as the loop parameter is already iterated by the FOR .. LOOP statement. It don't need an explicite declaration and must not be assigned a value.
Furthermore, the code doesn't work as intended. I understand, that href events shall be counted. But actually, the iteration is executed for each line. Basically, you can't build a counter this way.
