Problem with a code for assigning RAM location
anandanips
Junior Member level 1
the following modules is required 255 ram locations of 8 bit wide.i am writing code like this.
module xy(x,y,ram);
input x,y;
output [7:0] ram[0:255];
reg[7:0] ram[0:255];
to assigning value of ram location i am writing like
ram[0]=data;
ram[1]=data;
ram[2]=data;
ram[3]=data;
ram[4]=data;
.// where data is 8 bit wide.
that statements are exeuting in different case .
for output only one assignment statement (as above) will be appear.
my proplem is ,i am getting 2 error in the place of array declattion:
so , please can anyone clear my mistakes.and say the above assignment is correct or not also
answer to me
try this
module ram_data(
output wire [7:0] data,
input wire [17:0]address,
input wire ce,
input wire oe,
input wire we
reg [7:0] mem[255 : 1];
assign data = ce?(oe ?( we? 10'bz : mem[address]) :10'bz): 10'bz ;
initial
begin
mem[1] = 8'b01000000 ;// 64
mem[2] = 8'b00111111 ;// 63
mem[3] = 8'b00111100 ;// 60
mem[4] = 8'b00111000 ;// 56
mem[5] = 8'b00110001 ;// 49
mem[6] = 8'b00101010 ;// 42
mem[7] = 8'b00100001 ;// 33
mem[8] = 8'b00010111 ;// 23
mem[9] = 8'b00001100 ;// 12
mem[10] = 8'b00000010 ;// 2
end
endmodule
answer to me
Verilog doesn't allow passing a register array (such as 'ram') through a module port. Try passing only the 8-bit address and 8-bit data signals, as kalyansrinivas described.
It may help the discussion if you could show the complete module rather than just a few lines of code.
Please ask follow-up questions in the same discussion, instead of creating a new discussion:
