+ Post New Thread
Results 1 to 13 of 13
  1. #1
    Newbie level 6
    Points: 1,150, Level: 7
    sridhar.d's Avatar
    Join Date
    May 2007
    Posts
    13
    Points
    1,150
    Level
    7
    difference between encoder and decoder
    •   Alt18th March 2008, 13:21
      advertising
  2. #2
    Full Member level 3
    Points: 3,580, Level: 14
    Achievements:
    7 years registered
    Join Date
    Nov 2005
    Bg
    Posts
    187
    Points
    3,580
    Level
    14
    difference between decoder and encoder
    A decoder is a multiply-input, multiply-output combinational logic circuit that converts coded inputs into coded outputs, where the input and output codes are different. The most commonly used input code is an n-bit binary code. The most commonly used output code is a 1-out-of-m code (which contains m output bits), where only one bit is asserted at any time.
    If the device’s output code has fewer bits than the input code, the device is usually called an encoder. Probably the simplest encoder to build is s binary encoder. The outputs of a binary encoder produce a binary number that corresponds to the address of the activated input.
  3. #3
    Points: 7,630, Level: 20
    Achievements:
    7 years registered
    AdvaRes's Avatar
    Join Date
    Feb 2008
    At home
    Posts
    1,166
    Points
    7,630
    Level
    20
    differences between encoder and decoder
    The encoder encodes, the decoder decodes ?
  4. #4
    Full Member level 4
    Points: 3,327, Level: 13
    Achievements:
    7 years registered
    Join Date
    Apr 2006
    Posts
    233
    Points
    3,327
    Level
    13
    differentiate encoder and decoder
    Also depends on what type of device you are talking about. For example you get video encoders and decoders, in this situation it is possible to have only one input and one output.
    Exactly what kind of encoders / decoders did you want to know about?
  5. #5
    Full Member level 3
    Achievements:
    7 years registered
    Join Date
    Nov 2005
    Bg
    Posts
    187
    Points
    3,580
    Level
    14
    differences between decoder and encoder
    Yes, it was my mistake - I always think for digital devices, but it could be some analog device, too.
    •   Alt18th March 2008, 17:11
      advertising
  6. #6
    Junior Member level 1
    Points: 955, Level: 7
    Join Date
    Feb 2008
    Posts
    18
    Points
    955
    Level
    7
    related:www.blurtit.com/q335716.html
    actually an encoder encodes the message signal by removing redundant bits so that it is easy to transfer
    ex: haming code
    decoder is used to find the actual message whether it is rigtly coded or not
    •   Alt18th March 2008, 17:40
      advertising
  7. #7
    Junior Member level 2
    Points: 1,042, Level: 7
    Join Date
    Jan 2008
    Posts
    22
    Points
    1,042
    Level
    7
    write the difference between encoder and decoder.
  8. #8
    Member level 5
    Points: 1,396, Level: 8
    Join Date
    Feb 2008
    INDIA
    Posts
    84
    Points
    1,396
    Level
    8
    difference between encoders and decoders
    Hi Friend,
    Encoder is a electronic device that codes the data in such a way that is is needed for transmitting.
    Decoder is a electronic device that converts the coded data into the original data for furthur processing.
    Regards,
    Avinash.S.
  9. #9
    Junior Member level 3
    Points: 1,684, Level: 9
    Join Date
    Jul 2005
    Posts
    25
    Points
    1,684
    Level
    9
    difference between encoder decoder
    in digital circuits
    say you had 8 lines (8 lines) using an encoder you can use 3 lines to represet it (ie 000 to 111 )
    decoder does the exact opposite
    useful generally in memory unit
  10. #10
    Member level 3
    Points: 1,243, Level: 7
    Join Date
    Apr 2007
    Posts
    58
    Points
    1,243
    Level
    7
    difference between encoder & decoder
    simply the encoder encodes, the decoder decodes
    •   Alt25th March 2008, 09:51
      advertising
  11. #11
    Points: 988, Level: 7
    Join Date
    Jan 2008
    Posts
    19
    Points
    988
    Level
    7
    difference between encode decode
    encoder => convert something to a code
    decoder => get message back from the encoded message
    it is basically converting one code to another code depending or requirement. u can have a simple example of having data as hex form ie a group of 4 bits each and u have to represent it as a octal. thus u will read 3 bits of hex and can represent it as octals :). abhityagi85@gmail.com
  12. #12
    Member level 3
    Points: 1,180, Level: 7
    Join Date
    Jan 2008
    Posts
    61
    Points
    1,180
    Level
    7
    difference between an encoder and a decoder
    Encoder do the opposite work of decoder.
  13. #13
    Full Member level 5
    Points: 4,437, Level: 15
    Achievements:
    7 years registered
    Join Date
    Feb 2008
    Bangalore
    Posts
    289
    Points
    4,437
    Level
    15
    differencd between receiver and encoder
    Encoding is the process of converting the original message into a coded one, whereas decoding is the process of taking a coded message and converting it back to the original message. The process can be an algorithm that is applied for decoding and encoding, or they could be different. The words cipher and decipher can be applied in the same way.
    If you need more information, contact me
