Looking for schematic of a simple SWR meter
xandimg
Junior Member level 2
I'm working with simple antennas, and I need a design of a simple SWR meter. It don't need to have high precision!
Could you help me?
<font size=-1>[ This Message was edited by: xandimg on 2002-05-01 18:07 ]</font>
swr schematics
hello pal,
You could try using a toroidal sensor to tell you whether there is any kind of mismatch in your load (open or closed)... I've an old R*F*D*E*S*I*G*N* that suggests a circuit for doing so... I'll try to scan it and upload it somewhere... any f*p's??? I've only 10 points and cant use the file manager...
Will it help you somehow?
2000
simple swr circuit
thanks 2000,
i would like the schematics and also the PCB (if it's a critical design). i was thinking in a circuit that can be used with multimeter.
thanks a lot.
swr meter + jpg
This construction article may help.
swr meter demo
Thanks IBall!! It's very interesting. I'll try it. This file has a reference to "FAR circuits", do you know? There are a PCB layout for this SWR meter.
Best regards, Alexandre.
construction swr meter
I followed the reference to FAR Circuits to:
w*w.farcircuits.net/
I could find no artwork for this project, but the directional coupler subsection does not seem to use one.
Glad you found it useful!
toroid swr meter
Here is a collection of three simple SWR meter schematics and layout info that may help.
swr meter pdf
hey people,
I just cant get the files here... why?
Hey house_cat... just found the article... I´m scanning it... give me some days to upload and tell me where to upload because I can´t use FM...
regards,
2000
swr meter schematics
hello,
It´s me again, the file is ready to be uploaded, its 680kB long and has 4 jpg scanned files.
regards,
2000
pal swr meter
you need to make a small pcb to cover from 0 - 100 mhz
three strips 1 " wide and 3 mm between each strip
three diodes four resistors two caps and a connector and variable res to adjust the reflectoed power
very easy stuff
simply type into G*oogle.com
the search string using qualifiers
swr meter design -- schematics ++ demo software art
SWR meter
saya ingin membuat SWR meter dengan tampilan digital.
bagaimana dengan komponen dan rangkaiannya?
serta deign layout PCB ?
Added after 1 minutes:
I want to make a SWR meter with digital display.
how the components and circuit?
and PCB layout design?
Added after 16 seconds:
help me please
