+ Post New Thread
Results 1 to 12 of 12
  1. #1
    Junior Member level 2
    Points: 2,453, Level: 11
    Join Date
    Mar 2002
    Posts
    21
    Points
    2,453
    Level
    11
    Looking for schematic of a simple SWR meter
    I'm working with simple antennas, and I need a design of a simple SWR meter. It don't need to have high precision!
    Could you help me?
    <font size=-1>[ This Message was edited by: xandimg on 2002-05-01 18:07 ]</font>
    •   Alt1st May 2002, 17:06
      advertising
  2. #2
    Member level 5
    Points: 2,458, Level: 11
    Join Date
    May 2001
    Posts
    87
    Points
    2,458
    Level
    11
    swr schematics
    hello pal,
    You could try using a toroidal sensor to tell you whether there is any kind of mismatch in your load (open or closed)... I've an old R*F*D*E*S*I*G*N* that suggests a circuit for doing so... I'll try to scan it and upload it somewhere... any f*p's??? I've only 10 points and cant use the file manager...
    Will it help you somehow?
    2000
  3. #3
    Join Date
    Mar 2002
    Posts
    21
    Points
    2,453
    Level
    11
    simple swr circuit
    thanks 2000,
    i would like the schematics and also the PCB (if it's a critical design). i was thinking in a circuit that can be used with multimeter.
    thanks a lot.
  4. #4
    Junior Member level 1
    Points: 2,344, Level: 11
    Join Date
    May 2001
    USA
    Posts
    15
    Points
    2,344
    Level
    11
    swr meter + jpg
    This construction article may help.
    Uploaded file: DirCplr.pdf
  5. #5
    Join Date
    Mar 2002
    Posts
    21
    Points
    2,453
    Level
    11
    swr meter demo
    Thanks IBall!! It's very interesting. I'll try it. This file has a reference to "FAR circuits", do you know? There are a PCB layout for this SWR meter.
    Best regards, Alexandre.
    •   Alt2nd May 2002, 00:35
      advertising
  6. #6
    Join Date
    May 2001
    USA
    Posts
    15
    Points
    2,344
    Level
    11
    construction swr meter
    I followed the reference to FAR Circuits to:
    w*w.farcircuits.net/
    I could find no artwork for this project, but the directional coupler subsection does not seem to use one.
    Glad you found it useful!
  7. #7
    Points: 15,672, Level: 30
    Join Date
    Feb 2002
    USA
    Posts
    1,371
    Points
    15,672
    Level
    30
    toroid swr meter
    Here is a collection of three simple SWR meter schematics and layout info that may help.
    Uploaded file: swr.pdf
  8. #8
    Member level 5
    Join Date
    May 2001
    Posts
    87
    Points
    2,458
    Level
    11
    swr meter pdf
    hey people,
    I just cant get the files here... why?
    Hey house_cat... just found the article... Iīm scanning it... give me some days to upload and tell me where to upload because I canīt use FM...
    regards,
    2000
  9. #9
    Member level 5
    Join Date
    May 2001
    Posts
    87
    Points
    2,458
    Level
    11
    swr meter schematics
    hello,
    Itīs me again, the file is ready to be uploaded, its 680kB long and has 4 jpg scanned files.
    regards,
    2000
  10. #10
    THE BORG
    pal swr meter
    you need to make a small pcb to cover from 0 - 100 mhz
    three strips 1 " wide and 3 mm between each strip
    three diodes four resistors two caps and a connector and variable res to adjust the reflectoed power
    very easy stuff
    simply type into G*oogle.com
    the search string using qualifiers
    swr meter design -- schematics ++ demo software art
  11. #11
    Newbie level 1
    Points: 571, Level: 5
    Join Date
    Sep 2009
    Indonesia
    Posts
    Points
    571
    Level
    SWR meter
    saya ingin membuat SWR meter dengan tampilan digital.
    bagaimana dengan komponen dan rangkaiannya?
    serta deign layout PCB ?
    Added after 1 minutes:
    I want to make a SWR meter with digital display.
    how the components and circuit?
    and PCB layout design?
    Added after 16 seconds:
    help me please
    •   Alt30th September 2009, 06:24
      advertising
  12. #12
    Advanced Member level 3
    Points: 13,776, Level: 28
    Join Date
    Feb 2002
    Posts
    749
    Points
    13,776
    Level
    28
    Re: SWR meter
    Using www.google.com and searching for
    SWR meter digital display
    gives several hits. For example:
    http://kd1jv.qrpradio.com/butterfly/digiswr.HTM
    http://www.kolumbus.fi/juha.niinikos...r/swrmeter.htm
