Precision Peak detector or Sample/Hold circuit
anyone can share a peak detector??
Im gonna use it in 10Mhz ac signal with peak voltage ranges from 200mVpp - 800mVpp....I do have the design bit it only worked in 1Mhz.
thanks....
Use a digital potentiometer.
Hi keith1200rs,
Thanks for your circuit.
Do you have any related thing such as paper or document which concerns the above circuit.
It's grateful if you can give me some further info. of the circuit.
Regards,
TDF.
This is the sort of configuration I prefer for high speed.
Keith.
