Testing FPGA board for FPGA I/O clocks and DDR communication
apv1965
Junior Member level 2
Can anybody help me on step by step testing of FPGA board for FPGA IO Clocks working and DDR communications..
I am new to this and hence need step by step understanding of this. As a normal hardware person I need certain things like checking powersupplies and if they are reaching ot all the parts of the board correctly or not..
But I do not have exposure to testing DDRII comunications and DACs communication testing part.
pLease help
Re: Testing FPGA board
Try to use boundary-scan software like Scanseer to probe (and toggle) FPGA pins. Scanseer can record waveforms for FPGA I/Os, so you can see how your communication signals running.
Testing FPGA board
where can I get it
it is very easy to check the hw if you are using a cpu inside the fpga like microblaze or nios.
then you can run a sw test on your devices.
it will be very suitable for testing the ddr2 for example.
Testing FPGA board
check your power lies, rpipples, current, shape of clocks, before loading FPGA
then same after loading,
try to load FPGA with USB blaster
check temperature of the chip
