+ Post New Thread
Results 1 to 10 of 10
  1. #1
    Junior Member level 1
    Points: 970, Level: 7
    Join Date
    Jan 2008
    Posts
    16
    Points
    970
    Level
    7
    voltage divider bias bjt
    Will voltage divider biased circuit give me the same ICq and VCEq as with Emitter biased circuit?
    are ICq = Vcc/ (Rc+Re) and
    VCEq= VCC ??
    Thanks in advance :)[/img]
    •   Alt20th February 2008, 17:08
      advertising
  2. #2
    Advanced Member level 5
    Points: 17,526, Level: 32
    Join Date
    Oct 2005
    India
    Posts
    1,804
    Points
    17,526
    Level
    32
    bjt voltage divider
    yes... but the difference would be in the stability of ICq i.e. variation in Vceq with change in Vi
  3. #3
    Banned
    Points: 8,931, Level: 22
    Join Date
    Jan 2007
    Posts
    943
    Points
    8,931
    Level
    22
    voltage divider bjt
    Vb = [ R2÷(R1+R2)] * Vcc
    Ie = (Vb-0.6V) ÷ Re
    Ie ≈ Ic = Icq
    Vceq = Vcc - Icq * (Re + Rc)
    Regards,
    Laktronics
    1 members found this post helpful.
  4. #4
    Join Date
    Jan 2008
    Posts
    16
    Points
    970
    Level
    7
    bjt q point
    @Laktronics
    How come Vceq = Vcc - Icq * (Re + Rc) with an emitter biased circuit yet when it comes to obtaining Q point Vceq = Vcc ?
    And yet with voltage divider bias is it Vceq = Vcc - Icq * (Re + Rc) ?
    i'm confused :(
    Added after 5 minutes:
    @ A.Anand Srinivasan
    You and laktronics gave me different answer :)
    Does this mean that if i have a voltage divider and an emmiter bias circuit with the same Vcc, R1, Rc and Re I will get the same Q point? Yet voltage divider is more stable since Icq is not too Beta dependent? I am right... Im still a bit lost at this
    Thanks
    •   Alt21st February 2008, 04:33
      advertising
  5. #5
    Join Date
    Oct 2005
    India
    Posts
    1,804
    Points
    17,526
    Level
    32
    q-point bjt
    if Vceq=Vcc then no current will be flowing through the transistor
    emitter bias just gives a lil negative feedback to make the bias stable but voltage divider bias is more stable...
  6. #6
    Join Date
    Jan 2008
    Posts
    16
    Points
    970
    Level
    7
    q point bjt
    I see... so Vceq=VCC only when I am looking for Q point... since Ic= 0
  7. #7
    Join Date
    Oct 2005
    India
    Posts
    1,804
    Points
    17,526
    Level
    32
    bjt voltage divider bias
    dude you are confusing things.... Vceq can be equal to Vcc only when Ic=0... at Q point you calculate Vceq by using the Qpoint current Icq and hence the equation Vceq=Vcc-Icq(Rc+Re)....
  8. #8
    Join Date
    Jan 2008
    Posts
    16
    Points
    970
    Level
    7
    @A.Anand Srinivasan
    hey i'm really really sorry for my TOO elementary questions. I only have a book and this site (not enrolled;no teachers/classmates to ask help)for my usually careless mistake related questions.
    I get it now, i got the previous graph and this one mixed up....
    Thanks again
    •   Alt25th February 2008, 15:49
      advertising
  9. #9
    Join Date
    Oct 2005
    India
    Posts
    1,804
    Points
    17,526
    Level
    32
    voltage divider biasing
    dont feel sorry for these things.... after all we're all here to help each other... all the best... carry on....
  10. #10
    Full Member level 1
    Points: 2,027, Level: 10
    Join Date
    Feb 2007
    Posts
    95
    Points
    2,027
    Level
    10
    bjt q-point
    In voltage divider basing, the basing resistors are replaced by thevenin equavilent circuit.
    So equavilent resister Rb= R1R2/R1+R2
    and equavilent voltage source VB = Vcc*R2/R1+R2
    Therefore from base side you can write
    VB=IbRb + Vbe+IeRe that is same as written but the values of Rb is now different and equivalent voltage VB is different is voltage divider biasing.
    This is so because we require the value of stability factor S as small as possible. This we can achive by reducing Base voltage supply and hence through R1 and R2 only.
    For voltage divider biasing, ICq equation is given by Vcc= IcRc + Vce + IeRe therefore
    Ic= Vcc-Vce-IeRe/Rc.
    If you only consider Vcc/Rc+Re then it will give you saturation current and Vce= Vcc is cuttoff voltage only.
    Added after 1 minutes:
    Please read 5th line that is same as written in Emitter biasing method but the----
