+ Post New Thread
Page 1 of 2 1 2 LastLast
Results 1 to 20 of 31
  1. #1
    Junior Member level 3
    Points: 1,125, Level: 7
    Join Date
    Dec 2007
    Posts
    31
    Points
    1,125
    Level
    7
    89v51rd2 programmer
    Hello,
    I need a programmer circuit For P89V51RD2.
    I am going to use Flash magic software For programming the device with Serial port.
    Can any one give me the Circuit diagram for Programming the MCU P89V51RD2?
    Thanks In advance....
    vmax.
    •   Alt19th February 2008, 09:38
      advertising
  2. #2
    Full Member level 4
    Points: 3,146, Level: 13
    Join Date
    Dec 2004
    Posts
    239
    Points
    3,146
    Level
    13
    1 members found this post helpful.
  3. #3
    Join Date
    Dec 2007
    Posts
    31
    Points
    1,125
    Level
    7
    89v51rd2 isp
    I have seen that forum.
    I think there are problems with Reseting the device.
    Also, There is not any connection for PSEN.
    Can You Give me Circuit diagram with some Description..?
    Thank You...
    vmax
  4. #4
    Full Member level 4
    Join Date
    Dec 2004
    Posts
    239
    Points
    3,146
    Level
    13
    p89v51rd2 programmer circuit
  5. #5
    Junior Member level 1
    Points: 2,963, Level: 12
    Join Date
    Feb 2002
    Posts
    18
    Points
    2,963
    Level
    12
    p89v51rd2 microcontroller
    vmax, the schematic provided by FlashMagic is perfect, I have used the same circuit to program P89C51RD2, P89V51RD2, 89C669 etc. I provided two swithches, one for RESET and one for PSEN, P89V51RD2 does not require PSEN, I am using this for years without any problem.
    Regards,
    John.
  6. #6
    Join Date
    Dec 2007
    Posts
    31
    Points
    1,125
    Level
    7
    programmer for p89v51rd2
    Thank You very much for your reply and suggestions.
    I am impementing that circuit.
    Thank You...
    vmax
    Added after 1 minutes:
    I have implenented that Circuit diagram.
    The reset window is appearing.it is not get vanished.
    For how much time Reset window should appear?
    I am not getting device programmed.
    please, Help me!!
    Thank You....
    vmax
  7. #7
    Full Member level 4
    Join Date
    Dec 2004
    Posts
    239
    Points
    3,146
    Level
    13
    programmer p89v51rd2
    There are extensive helps for solving ISP problems on the FLashMagic forum site, as the first sticky post in the P89V51RD2 cathegory and the link therein. I have posted the links in your thread there, too.
    JW
  8. #8
    Join Date
    Feb 2002
    Posts
    18
    Points
    2,963
    Level
    12
    flash magic + 89v51rd2
    When the reset window appears, reset your target controller, make sure you have selected the 89V51RD2 (I am assuming this is the controller you are trying to program), select lower baud rates in the FlashMagic window initially, and ensure that you have downloaded the latest version from FlashMagic website.
    If I can recall, I had implemented the schematic from FlashMagic, but I added the level control chip, such as the MAX232, and the switches.
    As wek suggests you will get extensive help from FlashMagic website.
    John.
  9. #9
    Full Member level 4
    Join Date
    Dec 2004
    Posts
    239
    Points
    3,146
    Level
    13
    microcontroller p89v51rd2
    There is a gotcha in newer versions of FlashMagic: you need to DISABLE the DTR->reset option, if you don't have the "automatic-reset" hardware! (Options -> Advanced Options -> Hardware Config -> Use DTR to control RST tickbox)
    JW
    •   Alt20th February 2008, 16:11
      advertising
  10. #10
    Join Date
    Dec 2007
    Posts
    31
    Points
    1,125
    Level
    7
    flashmagic software for p89v51rd2
    Hello,
    I have implemented all the Circuit.
    And now I am getting all the things right and I have programmed the MCU P89V51RD2 succesfully.
    Thank You very much for all your support.
    vmax
    •   Alt22nd February 2008, 06:46
      advertising
  11. #11
    Newbie level 2
    Points: 1,108, Level: 7
    Join Date
    Oct 2006
    Posts
    Points
    1,108
    Level
    7
    p89c51rd2 isp program circuit
    Hi guys. I am designing a programmer for the P89V51RD2. Now i am going to program the microcontroller using the Rx, Tx pins only. Since im not goin to use PSEN should i leave this pin floating or connect it to +5V or GND?
  12. #12
    Full Member level 4
    Join Date
    Dec 2004
    Posts
    239
    Points
    3,146
    Level
    13
    flash magic 89v51rd2
    Floating.
  13. #13
    Newbie level 1
    Points: 471, Level: 4
    Join Date
    Apr 2010
    PUNJAB
    Posts
    Points
    471
    Level
    Re: p89v51rd2 microcontroller
    Quote Originally Posted by mercyjohn
    Regards,
    John.
    hello
    i also want to made the programmer circuit for p89v51rd2fn (40 pin). u hav given the link of a thread. but could open the circuit link given there,
    pls send the circuit on xxxxxxxxxx@gmail.com or give its that can be opened
    pls i will be highly thankful to u
    NO PRIVATE SHARING...
    USING SMS LANGUAGE IS NOT ALLOWED HERE
    [MOD]
  14. #14
    Points: 634, Level: 5
    Join Date
    Jul 2009
    Mumbai
    Posts
    7
    Points
    634
    Level
    hi all i m trying to program p89v51rd2 controller with flashmagic but i m not able to program it.it gives error as reset the device in isp mode now..even if i reset that window does not disappear ..plz can anyone provide me the circuit diagram for this..
  15. #15
    Advanced Member level 2
    Points: 6,569, Level: 19
    ctownsend's Avatar
    Join Date
    Nov 2004
    Canada
    Posts
    573
    Points
    6,569
    Level
    19
    Quote Originally Posted by Vignya View Post
    here you go.
  16. #16
    Join Date
    Jul 2009
    Mumbai
    Posts
    7
    Points
    634
    Level
    thank you ctownsend for your reply i did changes in my circuit according to the diagram given by you except all capacitors around max232 which are 10uF instead of 1uF.but still i m not able to program my ic.i m compiling my code in keil compiler tell me which include file i must include for p89v51rd2.if possible plz provide small hello program.
  17. #17
    ctownsend's Avatar
    Join Date
    Nov 2004
    Canada
    Posts
    573
    Points
    6,569
    Level
    19
    Re: P89V51RD2 programmer Circuit
    are you actually programming the micro controller?
    or
    is flashmagic giving you errors?
    try using hyperterminal at a low baud rate (like 9600)
    send an uppercase "U"
    if it echoes back, your programmer is working, the micro controller has successfully entered boot mode
  18. #18
    Join Date
    Jul 2009
    Mumbai
    Posts
    7
    Points
    634
    Level
    Actually when i try to program my uc using flashmagic i m getting massage as reset the device in isp mode now. but even if i reset this window doesn't disappear.i have tried loop backing using shorting the rx and tx pin and I m getting response on hyper terminal. does erase all erases bootloader in 89v51rd2?
    if i use include file of 89s52 for p89v51rd2 does it work?
  19. #19
    Join Date
    Jul 2009
    Mumbai
    Posts
    7
    Points
    634
    Level
    hey thanks for help. I changed my controller and i m able to program my controller now.....
  20. #20
    Points: 892, Level: 6
    Join Date
    Jun 2009
    Posts
    28
    Points
    892
    Level
    hey guyz!! do you need a reset switch and alongwith it unchecking the "Use DTR to control RST" in the advanced options of Flash Magic...
    Plz reply soon..
    •   Alt11th January 2011, 18:38
      advertising
